speakerfreak
Member
When the album gets done playing, the tonearm goes to the very edge of the clamp. Also when the repeat function is on this problem causes the tonearm to go to the center of the LP. Any ideas?
Take the bottom cover off. Attached to the tonearm near the base is a lever that the linkages push on to make it move. On the end of the lever is a rubber dampening pad that often gets gooey or sticky. Replace it with another piece of rubber or felt the same thickness and you should be ok.
Hard to see it from that pic.
Lemme open up one of my parts units and take a pic to point it out.
Here it is
Something is sticking. Probably due to old grease that is tarting to harden. pull the stylus out of the cart and operate the turntable with the right side hanging over your work area that way you can see the mechanism in operation and try to see what might be causing it to fail this way.
I thought I'd post a few pics of what mine looked like with the new pad put in place. The new pad is tan/beige in color.
I know the OP fixed his, but just in case someone stumbles across this thread and needs a few 'after' pics for reference.
Rob
What adhesive did you use to reattach the pad. I have a few other somewhat delicate parts I need to repair and was wondering about a safe adhesive. Thanks.
Regards,
D-Ray
