Please help! Offset set to zero but unable to set bias appropriately
when dc offset adjusts, yet idle current doesn't - differential voltage reading are your friend.
measure across the bases of the driver's (Q9, Q11 are they new? a1220/c2690) for 1.8v and that it IS adjustable over several tens of millivolts (at least) - use another channel for comparison
Then switch to the emitters and look for 1.2 volts less overall voltage BUT the SAME amount of millivolts adjustment as the bases had.
the way the voltages are determined is to start at zero volts and add in each stage's Vbe drop.
thus data is below
+/- 0.6v or 1.2v base to base at the outputs 1.30 is measured
+/- 1.2v or 2.4v differentially base to base at the drivers 2.1 is measured how much adjustment?
2.2 to 2.7 so it can vary about 0.5 volts
Then switch to the emitters and look for 1.2 volts less overall voltage BUT the SAME amount of millivolts adjustment as the bases had.1.31 to 1.52 so it varies only 0.22 volts.
What does this mean?
thus data is below
