kotofei
permanent gear evolution
Working on a Project Tube Box SE II phono preamp and it turns out its on/off switch is broken.
It's a pushbutton switch, most likely ON-OFF, located in 18 V AC 1A power circuit. Nothing is written on this white thing with contacts that is soldered to a two metal "poles" that are in turn soldered to PCB. Another white part with a little metal plate is mounted on top of this white thing. The black knob is mounted at the front of the switch and protrudes from the front panel hole.
The diameter of the white thing with contacts is 10 mm.
