Before annoying your neighbors, (provided this is 1st time you've had it powered up IF you did restoration, not a shop which should have done this) run some sweep tones thru it(on dummy loads) to assess it's capabilities, thd, total wattage, etc. If everything is up to spec, 1812 overture with actual cannon's comes to mind. That'd be enough to kick the neighbors in the guts. Then Dealers Choice.
