Bert Beukema
Well-Known Member
Hi guys,
today on my bench is an otherwise not very interesting amplifier, the Sony AX410. It's part of a system (early 80's) and it's owner wants it repaired. It was easy to see that one of the STK modules was broken, so far so good.
There is however a much stranger thing that i've actually not seen before. On this machine, the negative and positive rails seem to have switched. So, everywhere a + voltage is supposed to be, you will get a - voltage. And the other way round. This affects the entire main board. Oddly enough, the voltages are correct, just not the right polarity.
I've done some preliminary testing on the machine but the usual suspects all check out fine. So before I spent hours playing unpaid Sherlock Holmes i'd like to hear some thoughts from you guys.
Thanks!
Bert
Thanks!
Bert
