TravAndAlex
I recently picked up an early version 400 in pretty rough shape with the plan to refurbish it. As project funds are limited, it was a very unhappy surprise to learn that both output transformers are dead (no continuity on primary windings - I've tested pretty thoroughly and although it is rare to have both die, I'm reasonably confident this is the case with this one).
I've contacted all the transformer repair, rewind, replace options that have been suggested (Fisherdoc, Transcendar (not currently active), Gary Brown, Brian Sowter, and Heyboer) and the least expensive to date has been replacement transformers for $120USD each plus shipping to Canada from Heyboer. This is beyond current budgets and may make the refurb unobtainable.
This is until someone suggested checking with EDCOR. They can build exact duplicates for approx $85.00 each plus a one time design and setup charge of $350.00. Or they offer an off the shelf model for $54.60 the CXPP25-6.6K transformer.
THAT PRICE MAKES THE OFF THE SHELF OPTION VERY ATTRACTIVE!
Now this transformer does differ from the original. Most obviously with a single 8-Ohm secondary (not 4, 8 and 16) which if it would work, is fine with me as I would use the 8-ohm speaker connection anyway. It is 6.6K Ohm Primary Impedance rather than (going from Trancendar's spec sheet) 6.4K. FULL SPECS AND DIAGRAMS ARE AT THE BOTTOM OF THIS POST.
The question I have for you experts is: could the EDCOR transformers work? And by work, I mean sound good in this application? I absolutely understand this is no longer going to be 'stock' as originally intended. However, at this price I can go ahead with getting this unit working again, vs perhaps just having to sell or part it out.
What would have to be done to make them work? I assume I could just ignore the 4 and 16 Ohm taps and just hook up the 8 Ohm as normal?
The original just has 2 plate wires and a B+ on the primary. The EDCOR has these 3, plus 2 screen wires. What would be done with the additional 2 screen wires?
Would anything else need to change on the Fisher to make this work? I've picked up Metalbone's refurb kit (of course before I tested the output transformers - yes, very stupid I know).
TRANCENDAR
Early Fisher 400
Fisher Part Number T 1020-116
For Receivers with Serial Numbers Lower than 48000
6.4K Push-Pull to 4, 8, & 16 ohms 25 Watts
Frequency Response: 10 Hz to 100 kHz +/- 1 dB @ 1 Watt
Primary DC Resistance: 225 ohms
Primary Inductance: 90 H @ 120 Hz
Part Number TT-429-OT
Weighs 3.8 lbs. (1.7 kg)
EDCOR CXPP25-6
Wattage 25W
Primary (input) Impedance 6.6K Ohms
Screen/Grid Tap 40%
Secondary (output) Impedance Depends on model.
Frequency Response 20~20K Hz., <1dBu
THD+Noise <0.1% @ 1K Hz.
Bobbin Material Nylon 6/6 GF-30
Flamability Rating Class B 130°C
Core Material M-6 29 ga. grain oriented lamination steel
Secondary Insulation (transformer) Clear air dry polyester varnish
Termination UL1015, 20 ga. lead wire
Mounting Powder coated steel end bells
Color RAL 5010 Gentian Blue
Weight 4.5 lbs.
Compliance RoHS & REACH
I greatly appreciate any advice and guidance you can provide!
TRANCENDAR
Early Fisher 400
EDCOR CXPP25-6
Wattage 25W
Screen/Grid Tap 40%
Weight 4.5 lbs.
