RE: Min7 tweeter situation,I've been meaning to post this for reference so might as well do it here & now.
FYI: The "good/early" tweeters from the wood cabinet min7w are different than the ones in any of the metal cabinet min7.
So note that the early (good) tweeters from the wood cabinets are
not a direct fit in
any of the metal cabinets.
If one looks at pics of both,you can see the top side of the "good" tweeters from the wood cabinets are less sharply rounded and thus ever-so-slightly taller.
That is what keeps them from fitting in the metal cabinets,so that direct swap is a no-go.
Also the "early/good" metal cab tweeters are cut straight/flat across the bottom edge so they wont overlap the woofers.
So the early/good tweeters from a min7w will
ONLY be a direcf fit in those early min7w cabinets.
But
any tweeter from a metal cab
will fit in the early min7w cabinets that originally came with the "good" tweeters,as the mounting holes
are the same pattern.
This includes the later tweeters (w/concentric rings) from the metal cabinets.
vvvv Here
vvvv is a pic of a metal cabinet concentric ring tweeter (LH) and an early/good min7w tweeter (RH).
The tweeter on the left is 2 9/16" vs. 2 13/16" on the right,and trust me that 1/4" difference is crucial.
And to complicate this situation even further yet,the later "concentric ringed" tweeters in the min7w (wood) cabinets changed as well.
They're physically larger (everywhere) than any of the metal cab tweeters.
Also note that the mounting hole pattern for those later min7w is different as well,as it too is bigger.
So the "early/good" min7w tweeters wont be a direct swap into those later min7w cabinets.
So swapping tweeters in the later min7w will likely require tweeters from the same later min7w cabinets.
And those later concentric ring min7w tweeters wont fit in
any min7 metal cabs either (nor vice-versa).
Ask me how I know all this,,,LOL...
Pic
vvvv here
vvvv shows the metal cabinet concentric ring tweeter on the left,and a later min7w concentric ring tweeter on the right.
Sorry no ruler for size reference,still it's fairly obvious (visually) that these two tweeters
^^^^ above
^^^^ are
NOT a direct interchange...
Just look at the distance between the rings and the top/bottom of the tweeter,and then look where the mounting holes are relative to that.
Now you ask "why no comparison pics of the good tweeters from an early metal cabinet min7" ???".
Well,I did'nt notice these differences and had'nt come across any reference material pointing all this out.
So like a total DA I bought some min7w speakers whose cabs were rough yet had a nice pair of "early/good" tweeters in 'em.
I did so thinking I could swap those tweeters into my Optimus Pro7AV project speakers.
Well,that did'nt work out like planned,,,DOH !!!
So now I've been on the hunt for some "early/good" tweeters for the metal cabinets of those Pro7AV.
Below are those Optimus Pro7AV project speakers I mentioned.
Main item of note
vvvv here
vvvv is to look at just how tight the "fit" is for the metal cab tweeters.
Also note that I've swapped out the OE woofers for some kevlar woofers from a Optimus LX4.
Note should be made that these woofers were some NOS/NIB LX4 woofers.
More pics of that Project HERE >>>>
http://audiokarma.org/forums/index.php?media/albums/optimus-pro7av-project.484/
Also have done that LX4 woofer swap on my minty pair of early min7w that I had before all this got started.
Note to be made here is that these kevlar woofers were original "pulls" from a pair of trashed out Optimus LX4.
That's because those also differ ever-so-slightly from the NOS/NIB LX4 woofers that were used in the Pro7AV project above.
More pics of that project HERE >>>>
http://audiokarma.org/forums/index.php?media/albums/min7w-project.494/
Now of course all this relates to direct drop in fit,if one is inclined to swap out the plates,then that may change things,I honestly dunno.
All I can say 'bout that is I have never done so and as such I cant really say that it would even be adviseable,so swim @ your own risk if going
that route.
And yeah,the plan is to do the crossover mods (PZ 2.1 or ???) on both of these,and likely a few others if I'm happy with how these two pairs work out.
HTH
Bret P.
