RonaldP
I have been modifying a tuner starting a few years back which include fast recovery rectifier diodes, total recap and alignment. Yesterday I decided to triple the capacitance from 35v 3300uf to 40v 10,000uf for the main filter capacitors off the transformer as I seen some info of other preforming this modification and I was never happy with the tuner as it was clean back lacked dynamics. There modification also had a 0.01uf Poly Bypass capacitor which I tried to see effect by clipping on when on bench but decided to hold off adding now.
Since I was changing the original design I decide to put a oscilloscope on the I/O of the power supply board. Apparently the power supply design changed from the design I had and on research there are 3 iterations my tuner which I bough a DVD in a effort to get the exact one I have. Apparently the specification I have showed 6600uf of capacitance (2 3300uf parallel with different voltages 25/35v). Also my transformer voltages were off slightly high 21vac measured 20.5vac rms and 6.3vac measured 6.8vac rms. The DC rails were not balanced at the newly added 10,000uf caps one was 27.2v DC the other was 29.0v DC. The scope said there was 2 volts ripple but I had to trust the peak to peak measurement as I was not sure how to zoom in on ripple.
The sound after 24 hrs on variac and couple hours of listening showed a great improvement in air sound and highs sounded good but bass was flabby and loose and mids sounded a bit tinny.
My questions are
What should I be looking for in a good functioning power supply? (Why different voltages at caps I increased value of?)
What can I do to improve the mids and bass? (Poly Bypass caps on newly added 10,000uf cap?)
Since the specifications changed in the power supply it was either due to cost or sound quality or both. I have been told its all in the power supply many many times when it comes to high end equipment.
If needed I can added the tuner model number but hate to put information out there that is not vaild as I'm learning so though I would start the topic on a general approach to such matters that applies to all equipment.
My questions are
