Did you increase the value of the filter caps? I've got the same problem with my 2325 and it never happened in thirty years before I re-capped. Went from 15K to 18K on the filters.
Finally had a chance to pull the bottom cover off the 2245 and found there was no suppression cap installed by the factory (either on switch or receptacle).
Placing parts order tomorrow.
Wurlyman, would be curious to know how/if you resolve your issue.
Until I get the ambition to tear it apart again, I'm turning it on and off with the switch on the power strip it's plugged in to. I first turn the volume down and shut off the speaker switch.
Installed suppressor runningdog recommended, problem resolved.
If anyone else need to do this be sure to note proper orientation per graphic on device.
