Not a balanced output.
You need an 8 pin DIN plug. Buy one and make your own cable (or have it made for you).
If you buy an RCA to 8-pin DIN cable (if you even find one, which I doubt), it will most likely have a different pinout. That will be bad, best case the cable will not work, worst case you'll damage your amp and speakers.
According to the service manual, this is the way the plug should be wired:
Plug is male (left).
Pin 2 is ground (-) for both channels.
Pin 3 is L+.
Pin 5 is R+.
That's all you need to and should connect.
The other active pins in this preamp's output are 1 (power control output), 6 (spectrum analyzer output) and 7 (described as "H input in AFB on" - whatever the hell that is). You DO NOT want to connect any of these pins to your power amp, especially pin 1.
Pins 4 and 8 are inactive.
DIN plugs are confusing because they are symmetrical and it's sometimes hard to tell which side is which. If you're not sure which side is which when looking at the plug (for example whether the pin you're looking at is pin 4 or pin 5), connect the right channel first (pins 2 and 5). Ground is pin 2 which is in the middle, so it can't be confused with another pin. R+ is pin 5. If you get the side right you'll get the preamp output signal. If you get the side wrong, you will connect to the inactive pin 4 and get nothing. But because pin 4 is inactive, you will not damage anything.
It is important to get it right before connecting the left channel. If you confuse pin 3 (L+) with pin 1 (power control output) you will send 20V to your power amp input (if i'm reading the schematics right). That will be very bad.
Service manual from which I got this information is here:
https://freeservicemanuals.info/en/servicemanuals/viewmanual/Aiwa/GX120/BX120/
