Problem with EV Sentry 100as
Discussion in 'Speakers' started by notgwb, May 17, 2018.
  1. notgwb
    notgwb New Member
    1
    Hey guys, I have a pair of Sentry 100as with foam surrounds that started cracking about a month ago. I continued to use them, but only on low volume with the lows almost completely eq'd out. The one I used on my right channel developed a problem where the driver no longer produces sound, only the tweeter makes noise. Did I completely mess up the driver or is the crossover messed up?
  2. ivandezande
    ivandezande Super Member
    1,862
    Twin Cities
    You probably did some damage to the woofer as the crossover really can't go bad for the woofer circuit. Really should have just refoamed them instead of continued use.
    Pull the woofer and ohm it out, check for the tinsel leads to be connected at all points.
    jwrauch likes this.
