marantzman
marantz user
Hey guys,
I am setting the bias current and dc offset on my marantz 2235b.
let me tell you the procedure and then I will tell you my problem.
here it goes...
Connect DVM to the output terminals (speaker outputs).
Adjust R713, for 0 VDC.
Repeat for the other channel (R714)
Connect a DVM between J713 and J717.
Adjust R766, for 8mVDC.
Repeat for other channel.
repeat after 30 minutes
Connect a DVM between J804 and J805.
Adjust R806, for 35VDC.
The problem I am having is that in the first step when I connect
the DVM to the right channel (R714) It is opposite of R713,
when I turn it to the right it decreases VDC and when I turn it
to the left it increases VDC. It does opposite of what R713 does.
and either way I cannot dial it in to 0 VDC. The perviuous owner
of the stereo or maybe the factory had marked where the little dials
are supposed to be when they are set correctly, and the left channel
(R713) is still almost exactly where the marks are. If I set the right channel (R714) where the marks is, then the DVM reads about
0.696 VDC. I am using an Extech instruments true rms auto range
multimeter 430. What could be causing this problem? Could it possibly
be bad output transistors? Sometimes, not always when I turn on the stereo with the voulme all the way down I can hear this slight rumble or THUMP
noise in the LEFT speaker. However I cannot hear any distinct difference in the right or left channel while playing music.
I really need some help. I am scared to even hook this thing back until I solve this problem. I have everything else adjusted to specs
except the right channel dc offset.
I had previously posted that the right channel had a slight thump upon power up, but it is the left channel, however the left channel is adjusted correctly
here it goes...
