Project: KR-8010
Discussion in 'Kenwood-Trio/Kensonic-Accuphase' started by Super Noob, Oct 5, 2018.
  1. Super Noob
    Super Noob AK Subscriber Subscriber
    326
    Fort Myers, FL
    Here is the current patient.
    My first Kenny. Power switch was not working. Wasn’t too hard to fix.
    Flipped the wiring to unused contacts, removed snubber, and install a TRAIC modification per ksparky. 2nd time doing this mod. Worked flawlessly.
    Full recap well underway. More to come.
  2. Super Noob
    326
    Fort Myers, FL
    Here are the main filter caps.
    Tricky part are solder tabs. Went with 22,000uF in lieu of 18,000uF caps. Drilled off the old tabs and mechanically fastened to tabs of new cap tabs and soldered.
    Install 2.2uF bypass caps.
    New relay as well.
    New Power Supply Caps - Old
    New:
    gort69 likes this.
  3. KingBubba
    10,168
    Brooksville, Fl.
    Nice stuff. My 8010 has no wood and I really like the way it looks. I have never had to open mine up; so it was nice to see some nudies. Do you think you could provide a link to the triac conversion. I would like to read up on it. Thanks for an interesting thread.
  4. Super Noob
    326
    Fort Myers, FL
    http://audiokarma.org/forums/index.php?threads/kenwood-kr-9600-upgrade-mods-and-restoration.764088/
    There is a good picture / diagram from Echowars = in the link above.
    TRIAC
    576-Q6030LH5
    and 100 ohm resistor (i go with 1/2 watt)
    It is simple and the power opens via the gate of the Thyistor / TRIAC = no stress on the switch contacts.
  5. Super Noob
    326
    Fort Myers, FL
    Here are the AMP Boards:
    Outputs - no micas were on these... the heat sinks were isolated to frame with plastic mounts. I added micas anyways - just had to trim a bit to fit.
    Bias set to 50mV
  6. The Fuxtor
    The Fuxtor AK Subscriber Subscriber
    2,979
    Calgary, Alberta
    Very nice!!
    Super Noob likes this.
  7. Super Noob
    326
    Fort Myers, FL
    Preamp:
    FM Board:
    Tone Controls:
  8. Super Noob
    326
    Fort Myers, FL
    Call It Done.
    Here is the cap list:
    https://drive.google.com/open?id=1vR64nceIHzzPqHsHg76uJI3KkVbQqB_-
    Here is the trash heap - over 100 caps.
    Here Kenny sits on top of the SX-1250 to give you a feel for this beast:
    Summary = Think Bubba is onto something with this under the radar Kenny. Really easy to work on. Bubba let's keep the KR-8010 secret it to ourselves.
    :beerchug::beerchug::beerchug::beerchug:
  9. KingBubba
    10,168
    Brooksville, Fl.
    In the past I was running the 8010 in concert with the 1250 and it stood toe to toe with it for years. Nice job, enjoy.
  10. avionic
    46,508
    Fort Dodge, Iowa
    Adding mica where not needed. Increases thermal resistance. And decreases thermal conductivity. Not the best idea.
    tarior likes this.
