Question: Can I use a Dragonfly DAC in my car coupled with my iPod?
Discussion in 'DACs' started by 70'sMusic, Dec 3, 2018.
  1. 70'sMusic
    70'sMusic Active Member
    347
    Hi,
    Does anyone use a Dragonfly DAC with their iPod/iPhone and their car stereo? I tried it with an Apogee One and it didn't work (although there was something wrong with the refurbished One unit that I had). I know I can connect it but will they gain from the Dragonfly be too high for playback using my car stereo's "aux" jack?
    Thank you in advance for your help, I really appreciate it!
  2. whyaskit
    whyaskit music. Subscriber
    3,418
    Utah
    I’ve done that before. With a dragonfly v1.5. It worked well in my little Sentra.
    70'sMusic likes this.
  3. 70'sMusic
    347
    OK, cool. Thanks whyaskit.
  4. luckybaer
    luckybaer Thinks The Devil actually beat Johnny Subscriber
    284
    I do it everyday.
  5. spark1
    spark1 Super Member
    1,920
    The Great Midwest
    The only thing I might note is that this will not work with older iPods, which do not offer digital output (other than via their docking connector, and even then only thru a few DACs with docking connectors that Apple licensed. Some GM vehicles provide integration with iPod devices based on USB connectivity; I believe that this approach takes digital output from the device and processes it via the vehicle's DAC.
    I don't know if iPod Touch or iPhone products allow for digital output to a USB DAC.
  6. spark1
    spark1 Super Member
    1,920
    The Great Midwest
    I'm curious as to what Apple device and what DAC? How is the DAC connected to the music player, and how is the DAC powered? Thank you!
  7. spark1
    spark1 Super Member
    1,920
    The Great Midwest
    How was the Dragonfly USB (male) connected to the Apple device? And was the Dragonfly drawing its power from the Apple device? Thanks!
  8. GChief
    GChief Not well known, super member or other silliness Subscriber
    2,536
    Eastern NC
    I do my 6s to a Teac Amp/DAC and AuneT1 Amp/DAC via USB on both.
  9. luckybaer
    284
    iPhone 7 with camera adapter to DragonFly Red to aux cord to aux input. Lightning cable plugs into camera adapter and is fed by the outlet in car.
    DragonFly Red powered by iPhone, but iPhone is charging, so battery stays full for my commute.
  10. whyaskit
    3,418
    Utah
    This. I use a camera adaptor the allows for charging of the iPhone as well. But you can just run the newer dragonfly dacs just off of the iPhone battery. The original dragonfly pulls too much power to be run off of the iPhone/iPad.
    luckybaer likes this.
  11. spark1
    spark1 Super Member
    1,920
    The Great Midwest
    Cool. So I thought that the Dragonfly is designed like a thumb drive, with a male USB? Does the adapter cable have a female USB? Or did you have to get an adapter for the adapter?
  12. 70'sMusic
    347
    I'm not familiar with the camera adapter method, but I thought you could use the headphone out from the Dragonfly to your car stereo's AUX input?
  13. spark1
    spark1 Super Member
    1,920
    The Great Midwest
    The camera adapter feeds a digital stream from the phone to the dragonfly.
  14. 70'sMusic
    347
    Thanks spark1. Won't an Apple lighting to USB cable or adapter work as well or are they the same thing?
  15. GChief
    2,536
    Eastern NC
    With the lighting cable if whatever your plugging into doesn’t have its own power it will be running off the phone battery. I use a lighting cable into both my DAC/Amps but one is rechargeable and the other has a PS. I also use lighting cable in my rental cars if Indont just BT it.
  16. 70'sMusic
    347
    Do you hear a noticeable difference/improvement in the music using your Dragonfly DAC?
  17. GChief
    2,536
    Eastern NC
    I don’t have a Dragon Fly, I was answering the power question. All my DACs make a noticeable improvement.
  18. 70'sMusic
    347
    Thanks!
