Wigwam Jones
Caesar non supra grammati
I resurrected an ancient Voice of Music Stere-o-matic four-speed changer today, and it seems to run pretty well now that I've gotten it going again. It has a Sonotone 8T cartridge and stylus in it.
It came in a V-M console from 1958 that I pulled the tube amp from, so it's been languishing for some time. But I decided to see what I could do to bring it back to life.
Now that it's spinning, I took the RCA outputs and put them into a vintage solid-state receiver but I noticed that I have a little issue with it.
The ceramic cartridge puts out a higher voltage that the typical magnetic cartridge, so it's 'too hot' to run into a phono input on the receiver. On the other hand, it's too low for the aux input.
Hmmm, what to do, what to do. I could put the original tube amp back into it, no problem there, but I was also wanting to record the output, and the original tube amp does not have a record-out capability.
Any thoughts on this? Is there perhaps an external phono pre-amp available for ceramic carts? I'm mostly wanting to play 78 RPM records with it. I have a more modern turntable that has 78 RPM speed on it and a Shure 91ED cartridge, which I believe I could get a 78 stylus for, but I'd like to see what I can do with this old V-M changer. Thanks for any ideas.
