bjlefebvre
Super Member
As you may have already seen, I'm building a Decware SE84C clone using a Edcor XPWR107 power transformer. I wasn't measuring any voltage out of the secondary tap (well, technically, 0.8V where the wire first entered the PCB board and then 0.0V at the tube heater pin, which was the very next point on the board) which led me to believe that I must have twisted the wires too hard or otherwise accidentally yanked them too hard when I was fitting it onto the top plate. But I just removed the transformer from the amp and did a continuity test on the two secondary tap wires - and heard the beep. If there's continuity, wouldn't that indicate the secondary tap is just fine and the amp's problem lies elsewhere?
