I'm having trouble setting the DC Balance (Offset) on both amp boards on a Spec 4.
Focusing on the power supply, I noticed a different reading between the plus and negative sides of the 68.0v regulators.
In Autorange, the positive 68v my Fluke reads in the tenths as 66.8v's but on the negative side, it reads 65.85, in hundreds. Why does this extra decimal point show on one reading and not the other?
In Manual range and it reads only in tenths. (00.0v's)
The balance wonders 100mV's up and down on both amps and I believe it's in the negative side of the regulated supply but having trouble isolating it. The positive is stable but the negative fluctuates as much as 0.05 volts and I can see it coincides with the wondering offset.
The PS has been rebuilt with new transistors, zeners, diodes and caps.
