R-2000
Discussion in 'Yamaha' started by Ryanj52, Apr 13, 2018.
  1. Ryanj52
    Ryanj52 Active Member
    185
    I got my first Yamaha Receiver R-2000, I bought it not tested knowing that it might not work. Well it doesn't, it turns on lights up, the turner seams to work but all I am hearing is occasional static or crackling and popping. I tried Aux, Tuner, and both Tape inputs, all with the same issue. If I tap the top it will make these noises on command. I am going to bring it somewhere to have it looked at, but would love to have an idea what it might be before I have it looked at. I always wanted one of these and decided to pick it up even knowing there were some issues.
    Any ideas would be appreciated,
    Thanks Ryan
  2. OMGCat!
    3,206
    El Sereno, CA
    It's worth trying to clean the selector with deoxit or at least turn it back and forth a bunch of times.
    I had an R-300 that made no noise at all due to an extremely dirty selector.
    Ryanj52 likes this.
  3. Ryanj52
    185
    Thanks I will give that a try
  4. avionic
    45,470
    Fort Dodge, Iowa
    Turn the volume control down low and toggle the front panel Pre/Main Coupler switch for shits and giggles.
    Ryanj52 likes this.
  5. Ryanj52
    185
    I will, Thanks!
  6. Ryanj52
    185
    This afternoon when it was making noise i could also hear a relay click. I took top cover, bottom and face plate off to tried to clean the pots and switches, they are pretty hard to get to, i may have to take more a part. I put it back together and now I am getting nothing. I don't know if i got deoxit on something I shouldn't have. I am going to try again tomorrow.
  7. SoCal Sam
    SoCal Sam Lunatic Member
    19,090
    Picker's Paradise
    Relay click and working tuner are good signs, especially the finicky tuner.
  8. Ryanj52
    185
    Today I am not hearing anything no music, no static or cracking and no relay click. It lights up the turner locks on channels, the power outlets in the back work. I tried speakers a,b and c and all inputs. I am not sure what else to try.
  9. avionic
    45,470
    Fort Dodge, Iowa
    You may have pulled a wire loose or pinched a wire when you were cleaning your switches.
    Ryanj52 likes this.
  10. Ryanj52
    185
    Thanks I didn't think of that, I will double check. The pots are tough to get to, I took the top cover, bottom and face plate off and still couldn't get them all without taking it further apart. I was afraid maybe I got deoxit on something I shouldn't have.
  11. Sawman
    Sawman New Member
    19
    I'm going to say what is probably obvious but sometimes it's the obvious that gets overlooked...are the pre-main jumpers installed?
  12. avionic
    45,470
    Fort Dodge, Iowa
    This model does not have jumpers. It does however have a (pre/main) coupler switch on the front panel.
  13. Sawman
    Sawman New Member
    19
    So if it has a switch to select pre or main, should it also have pre outs and main outs? And should those be jumpered if not using an external amp?
    Not trying to be sarcastic, because I have an R1000 and they seem to be similar.
  14. avionic
    45,470
    Fort Dodge, Iowa
    It has the pre-out / main-in jacks. But the switch functions as the physical jumper. Yamaha does not use physical jumpers. Or at least I can't at the moment recall any model that does.
  15. Sawman
    Sawman New Member
    19
    Ok cool. The R1000 has to have a jumper.
  16. avionic
    45,470
    Fort Dodge, Iowa
    No it doesn't.. Not according to the schematic and owners manual. It is the same as the R-2000..
  17. avionic
    45,470
    Fort Dodge, Iowa
    If your using jumpers. Your just by-passing the coupler/decoupler front panel switch.
  18. avionic
    45,470
    Fort Dodge, Iowa
    If your 1000 has a set of jumpers. They are not OEM. Someone has added them probably because the coupler switch is dirty and not working correctly.
  19. avionic
    45,470
    Fort Dodge, Iowa
    A poor engineering decision IMO. Those coupler switches are most always and issue. I would say in 75-80% of the Yamaha recievers and integrated amplifiers I've had across the bench.They needed disassembly and cleaned. Jumpers would have been a cheaper and more reliable way to go.;)
  20. Sawman
    Sawman New Member
    19
    Lol, definitely in my case! Couldn't get sound without a jumper.
