I'm in the process of building bass traps and sound control panels for my garage listening area pictured below. For the traps I'm going to build floor to ceiling panels to triangulate the walls that form the two corners behind my speakers and will use R19 fiberglass batting as my absorption medium with the typical wood frame and burlap sandwich.
I studied the Bob Gold absorption coefficent chart (link below) and found that 6" of fiberglass battting, if given some air space behind, compares very favorably to 4" of 703. They have almost the same coefficient values across the frequency range with exception to 125hz where 6" ofthe R13 is actually 33% better than 4" thick 703. The value of the R19 is undeniable compared to the 703. To build my panels it'll take $35 to achieve the same level of performance as $210 worth of 703. And at that much value I intend to double the thickness of R19 in my panels from 6" to 12" which should add even better LF absorption.
Frequency (hz).................125...250...500..1000..2000..4000
703, plain 4" .........16" air 0.65...1.01..1.20..1.14..1.10....1.16..1.10
Unfaced 6.25" R19..16" air 0.96...1.03..1.13..1.02..1.04....1.13..1.05
http://www.bobgolds.com/AbsorptionCoefficients.htm
Now, I need some opinions wrt how to deal with the hot water heater I have in the corner. My plan is this...If I triangulate the two walls and put the hot water heater just behind the panel my panel width will be 5'. This creates a distance of 30" from the corner to the panel...or the height of the triangle formed by the panel and two walls. I expect the water heater will create reflection and RevMen suggested it would actually create some diffusion, but it's obvious it will consume some of the volumetric air space behind the panel. To balance this in the opposite corner I intend to stack some speaker boxes to create an eqivalent amount of surface area. I will then cover the water heater and speaker box stack with one 6" layer of R19. Hopefully the air space above the water heater/speaker stack will be sufficient to create the "buffer zone" that is represented on the chart by the 16" spacing from the wall. Please offer your opinions/observations.
One final question...is there any benefit to compressing the fiberglass batting as much as possible inside the burlap "sandwich"?
[/IMG]
