Yes they are same for AU-217/317/AX-7I'm not certain, but I believe there are only two sizes of rack mount handles made by Sansui for their late 70's gear. Can someone tell me if the rack mounts for the AU-217/317 fits the AX-7? They all look about the same height.
Thanks,
Kevin
..and there are SC-1110/SC-2110/SC-3330/SE-5/SE-7/SE-8/TA-300/TA-500/AU-D5/AU-D7/TU-S5/TU-S7 probably more.you left out the AU/TU 717, 517 719, 819,
Yes they have different parts numbers as well.My SE-7 has different ones than my AU-919/TU-919 does, FWIW. They look like the same but one is plastic and the others are metal.
part number hole placement Model high
72 963 900 horizontally CA-F1, RX-50 6,0 cm
7 726 700 4,5 cm TU-S5/S7/S9 (B) 8,3 cm
5 396 350 6,6 cm AU/TU-117/217/317, AX-/MA-7, (RA-900? RX-10 11,0 cm
5 396 700 6,6 cm AU117II/217II/317II, SE-5, (RA-900? RX-100? 11,0 cm
7 712 200 8,0 cm D-350M/550M (B), SE-8 (B) 12,8 cm
7 667 900 8,0 cm AU-D5/D7 (B) 14,8 cm
7 767 900 8,0 cm SE-9 (B) 14,8 cm
? RX-150 15,0 cm
72 963 600 10,0 cm SC-1330/3330 16,0 cm
5 396 340 10,0 cm AU-517/717/719/819/919, TU-717/719 16,8 cm
5 396 720 10,0 cm TU-417/517/519/919, TA-300/500, AU-417 16,8 cm
xxxxxxxx 10,0 cm SC-2110/3110 16,8 cm
5 397 100 10,5 cm SE-7 (B) 15,9 cm
5 390 080 10,5 cm SC-1110 16,0 cm
72 964 000 11,0 cm SC-5330, BA-F1 18,7 cm
This is the same size as the TU/AU 517, 717, 519,719, 919 and EQs like the SE-7 and many other components. It's the most common size but the 519 had plastic handles like the SE-7, best replaced with metal ones. I had a mint AU-519 and my friend now has it, kinda rare and it was only around for one year.What about the sansui AU-519, TU-519,
