Ravenswood Console
Discussion in 'Tube Audio' started by drumbum, Sep 11, 2018.
  1. drumbum
    drumbum Super Member
    1,333
    Picked up a model 502 Ravenswood console. Works...with hum. Played record to test...working.
    Separate amp section with telefunken tubes...not sure which though.
    What to do, what to do?
    Hmmmm
  2. RWood
    RWood Nobody goes there anymore. It's too crowded. Subscriber
    1,544
    Richmond, VA
    Please show pictures! Does the separate amp use ECL86 tubes?
    I have the amp but no preamp - I have been looking for info about it.
    For the hum, likely needs new filter caps. Does the hum appear on both channels and is it independent of the volume control?
  3. drumbum
    1,333
    Yeah, believe so on the hum.
  4. gadget73
    37,346
    Southern NJ
    These have come up as a subject of discussion a few times. You've probably heard the rumors of links to EH Scott, etc. I've seen pics of one of these before, and i seem to recall it appeared to be a well built unit, regardless of any possible affiliation to EH. If you have the complete console, I understand they are pretty rare so it may be worth keeping together.
    Agree on most likely being filter caps though.
  5. drumbum
    1,333
    Tubes look to be ECL86/6gw8. Four of them. Push/pull config., correct?
  6. RWood
    1,544
    Richmond, VA
    Yessir. That’s what mine has, too. Each of those tubes has a triode and a power pentode in it.
    I believe the power amp also powers the filaments of the preamp tubes, some with AC and the phono tubes with DC. I’d love to get some shots of the preamp when you get a chance, above and below deck.
    We can guide you through the recap if you’d like.
  7. drumbum
    1,333
    Piccys will be a while until I find a place for it. Still in van.
    Leland47 likes this.
  8. RWood
    1,544
    Richmond, VA
    That's cool - I can use them whenever.
    In the mean time, here is the power amp that I have:
    kirkendoll likes this.
  9. drumbum
    1,333
  10. drumbum
    1,333
    It is an ugly little thing.;)
  11. drumbum
    1,333
    Anyone have an idea about output wattage of the ECL86 in push/pull?
  12. Tinkerbelle
    Tinkerbelle Everything in Moderation Staff Member Super Mod Moderator Subscriber
    6,294
    Hudson Valley, NY
    drumbum likes this.
  13. drumbum
    1,333
    Thanks for that Tinkerbelle.
    How did you decipher that to come up with the max watt output? Plate dissipation or math?
  14. drumbum
    1,333
    For those interested.
    Tubes on amp Telefunken 4x 6gw8/ecl86 and 1x 6ca4/ez81
    Preamp tubes Telefunken
    2x ecc81/12at7
    1x ech81/6aj8
    1x6ba6/ef93
    2x shielded unknown: now known 12ax7a/7025 sonotube andecf80/6bl8 telefunken
    and one Ratheon 6au6
    How do you differentiate between type 1 6gw8 and type 3?
    Three of these 6gw8 test good as type one, and one test bad, but tests good as type 3.
    Will try to post pics later.
    PS...this pre amp was a bear to get out because the volume knob had been glued on...sheesh
    Speakers are 8" Jensen w/ceramic magnets and tweeters I assume are Jensen also w/AlNiCo.
    RWood likes this.
  15. drumbum
    1,333
    Amp has a little pot adj. Would this be for matching gain to the pre?
  16. gadget73
    37,346
    Southern NJ
    need a schematic or at least internal pics. I'm guessing hum pot though.
    what do you mean type 1 and type 3 6GW8 ? They are a two section tube, so there is a triode and a power pentode section to test. Both must be good for the tube to actually be good.
  17. drumbum
    1,333
    I believe its a bias pot.
    Gotcha on the 1 and 3. Not up to speed on tube stuff yet, (and grinding gears on SS)
    All tubes on amp have tested good on my tc-20.;)
