I've seen the builds for RCA cables. I'm interested in doing one with Canary star quad cable. All the bills I've seen use one cable or RCA, tying two lines to center pin, two cables to outer pin (sleeve, ground) and shield to ground on one end. With Canary having for conductors, could I use single cable for RCA pair? 1 conductor for left channel pin, second conductor for left ground, third for right channel pin, fourth for right channel ground? I would then have to tie the shield to both left and right grounds on one end and leave floating on the other end. Since I haven't seen this done I suspect it won't work, and I suspect it's the unbalanced shield. Can someone elaborate on why not if that's the case and what unbalanced signal mean and why it's important? Thank you.
