RCA lead repair help?
Discussion in 'Turntables' started by Joel66, Aug 12, 2018.
  1. Joel66
    Joel66 AK Subscriber Subscriber
    843
    Cypress Inn, TN
    Okay, I'm sober enough to try this. Kidding. My hands aren't shaking too bad today so, I wanted to try and get my SP-15 up and running.
    The first photo is what I'm working with.
    I'm assuming, whomever cobbled it had the right idea. I don't know whether to solder the wires together or, solder on new ends.
    These are the new ends I have. What would be the proper way to solder them?
    Thank you for any, and all, help.
    Joel
  2. Stanton681EEES
    Stanton681EEES Addicted Member
    7,314
    NE Ohio
    Not sure what I'm looking at but I'd opt for soldering on new ends.
    Joel66 likes this.
  3. stoN_Cold
    stoN_Cold Super Member
    3,466
    Belgrade, Serbia
  4. petehall347
    28,327
    uk.. the middle bit
    is there a hole on the ground lug ?
    Joel66 likes this.
  5. Joel66
    843
    Cypress Inn, TN
  6. Joel66
    843
    Cypress Inn, TN
    The black leads were patched on at some point.
  7. petehall347
    28,327
    uk.. the middle bit
    i solder ground in that hole and crimp . then solder the signal wire in the pin . pin upwards letting solder melt into the hole of the pin . but doing all this making sure its not melting the plastic . heat rises but still travels downhill through metal .
    Joel66 likes this.
  8. stoN_Cold
    3,466
    Belgrade, Serbia
  9. stoN_Cold
    3,466
    Belgrade, Serbia
    tcdriver likes this.
  10. petehall347
    28,327
    uk.. the middle bit
    Joel66 likes this.
  11. petehall347
    28,327
    uk.. the middle bit
    i would be tempted to buy ready made quality cables and replacing the old cables . to me its easier and makes for a better job .
    Joel66 and mprince like this.
  12. Joel66
    843
    Cypress Inn, TN
    I'm just working with what I have on hand. If needed, I'll pick up other parts
  13. petehall347
    28,327
    uk.. the middle bit
    watch the heat whilst soldering .. hot and fast is maybe best . its whatever works for you that counts .
    Joel66 likes this.
  14. Joel66
    843
    Cypress Inn, TN
    Gonna have to try again another day. I can't figure out which is worse...my eyes or my hands. Lol
  15. petehall347
    28,327
    uk.. the middle bit
    i know the feeling .. am sure i have seen ones that dont need soldering . just 2 tiny screws to turn .
    Joel66 likes this.
  16. petehall347
    28,327
    uk.. the middle bit
  17. stoN_Cold
    3,466
    Belgrade, Serbia
    Ok, why not use new cable in one piece. :rockon:
