Audi0
Super Member
My other thread is going off topic I thought I would start this one.
I followed a few rebuild threads using the recommended parts here on audio karma.
The only unknowns were the ksc3505 replacing the 2sd688 and the the itt-73n diodes were replaced with 1n4148 diodes.
All resistors were pulled checked and if bad replaced. Same with caps and transistors
One channel wants to short out and the other I don't have bias control with dc offset. Amp will not pass dim bulb test. And ideas how o can track this down.
