It's been about 3 months since I finished the restoration on my 500C. I had one cold solder joint that gave trouble when the unit heated up, otherwise I've been extremely happy with the unit's performance (used 1-5 hours/week, depending).
I've noticed a barely audible hum in the unit, I'm not sure if it's new or if I just never heard it before. It sounds like 120hz-ish, not sure. I can only hear it if my ear is an inch away from 92db woofers, and it's independent of the volume control. it's also the same in both speakers so I suspect it's power supply hum on the power tubes.
My question is whether this is worth chasing down. On the one hand, it's an old unit and I can't hear the hum at all if my ear isn't right on top of the woofer. On the other hand, it could be a symptom of a drifting resistor value in the PSU or something similar. Should this thing be absolutely dead quiet, or should I just not worry about it? Opinions?
