Pioneered
Well-Known Member
I hope this is the right place to put this, I reckon if not I'll hear about it.
I have questions that hopefully someone can help answer in a way I may comprehend being that I'm not the sharpest pencil in the box anymore. Just so you'll know my short experience, I've recapped motherboards and vintage radios, even some vintage telephones , yes in the old phones there's at least one. But, all the recaps have been done were with the same that was removed except for dual capacitors naturally and some that just aren't made in the same values anymore.
So my question is how does one know when to replace one type (mainly electrolytic) with another and when might you want to change value and or voltage? (knowing that most the time a higher voltage rating doesn't matter)
One more question if I may, what does it really matter if you just recap with the same values or as close as you can get using in series or parallel?
Maybe I'm asking too much, I'm not sure really cause I look at replacing components as fairly simple procedure
done the way I've always done it. Thank you for any insight.
