A CD player has a DAC inside. Any line-level pair of RCA input jacks on the receiver (Aux, Tuner, Tape) will work for the connection.
I am looking for a CD player w/ built-in DAC for my Kenwood KT-907 integrated amplifier. Prefer brushed aluminum finish to match my existing vintage gear. Trying not to spend all the grocery money.
I like my Sonys, all of these originally sold for $1000 or more, all purchased on eBay for $80 or less.
Have two of these, both are black, still looking for one in silver that isn't $300 and in Russia lol
Sony DVP NS900V
Have one of these in silver
Sony DVP NS999ES
Have one of these in silver, paid $63 needed belts, another $12 and it works like new. The belts are easy to install, couple of screws remove the cover and there they are.
Sony DVP CX777ES
So I have my cd player connected to my integrated amp thru a coaxial cable. So my amp has a built in DAC. Does the music travel through both DAC's or just bypass the cd player and uses the amp DAC?The OP seems to be struggling with the notion of a DAC.
All CD players have a digital to audio converter (DAC) built into them. It is fundamental to their function, which is to read and then convert digital information (from the CD) into an analog waveform. And, they all have analog outputs (right and left). These are the same as the outputs from a tape player or tuner, and can be plugged into any analog input on your integrated amp (which, by the way, is a KA-907...not KT-907), other than Phono 1 or Phono 2. Specifically, a CD player can be plugged into AUX, TAPE IN, or TUNER jacks.
Note also that you can use a DVD player or Bluray player as a CD player.
If your confusion is due to the existence of standalone DAC units; these provide the conversion function only. They do not read any media. Rather, they simply take digital audio input (from, for example, music files streamed thru or stored on a PC) and convert them to analog, so that they can then be played through your analog music system.
You can use an external DAC with a CD player, if and only if the CD player offers the option of digital output...by which it bypasses its own DAC and outputs the digital information it has pulled from the CD so that it can processed elsewhere. Generally, only higher end CD players offer this option. This arrangement offers the ability to use a higher quality DAC than the one in the CD player. The digital output from the CD player would go to the external DAC unit, where it would be converted to analog. An external DAC, therefore, has a digital INPUT and analog OUTPUTS. There are differences in the sound of various DAC designs; an external DAC allows the user to choose a different DAC than the one built into their CD player (or computer, or DVD player, etc).
It would be great if you would follow up on threads you have already posted if you have additional questions or confusion.
All CD players have a DAC. At least, if it has RCA analog output jacks. Or are you looking for a CD player, that also has digital inputs? There are players with digital inputs, but they aren't cheap. Pricing starts at around $500 for Marantz and NAD players, with USB inputs. Silver face and digital inputs, never-mind. A Yamaha CD-S2100 goes for $2999.
It seems to me you'd be better off with a decent CD player. Then, when you feel the need to upgrade, add a standalone DAC.
'Luck.
Cambridge has a CD player that does not have a DAC.
Rotel has a couple of modeles ($600-900 range) that got recommended components by the Absolute Sound.
If it doesn't have a DAC, it's not a CD player...it's a CD reader.
