MCM_Fan
AK Subscriber
Ok, I've googled this topic several times and read everything I can find in this and other forums. I am well aware of the warnings: Do NOT use Deoxit on the volume pot of the Sherwood S-7100A, or other Sherwood receivers that have the on/off switch integrated with the volume control.
It is well documented that Deoxit, and other cleaning solvents make the plastic on the on/off switch brittle, leading to irreparable failures. I understand the problem, and I am well aware of the work arounds for a failed switch. Believe me, those are easy to find using google.
I am one of the lucky ones that has a Sherwood S-7100A with a working on/off switch. My problem is the volume pot REALLY needs cleaned. It is VERY noisy.
So, what is the recommended way to clean this volume pot without destroying the on/off switch? I haven't been able to find a single recommendation, just the warnings against using Deoxit or other solvents, the work arounds for failed switches and a few people that said just live with the noisy volume pot.
Does anyone have a proven method of cleaning the pot without damaging the on/off switch? Would something like isopropyl alcohol work, or would that also make the plastic (polycarbonate) in the switch brittle and prone to failure? What about disassembly and manually cleaning the contacts with some 600 grit (or higher) emory cloth, or polishing them with a pencil eraser?
Other than the noisy (and I mean REALLY noisy - worst I've ever heard) volume control, this little Sherwood is a great sounding vintage receiver. I'd really like to get rid of the noise in the pot without damaging the switch.
