Recommended software for confirming actual output resolution
Discussion in 'Digital Sources' started by Alobar, Feb 12, 2019 at 2:01 PM.
  1. Alobar
    5,856
    SE Alaska
    Im trying to troubleshoot my MiniDSP 4x10 to determine if it is outputting at track resolution up to 24/96 and not capping at 48K. What would be a good straight forward program that will do this?
    Thanks.
  2. Decibel_116
    Decibel_116 AK Subscriber
    2,115
    Madison, Alabama, USA
    Open the file with Audacity and see what the properties show.
  3. Silentnet
    1,025
    Charleston, SC
    He wants stats effectively /after/ output.
    Alobar likes this.
  4. Decibel_116
    2,115
    Of course an APx digital analyzer would do it, but that is probably a little overkill for this application.
  5. Silentnet
    1,025
    Charleston, SC
    Yes, but then he would have one of those, and imagine the fun to be had! (It's probably like $10k, huh.)
    Decibel_116 likes this.
  6. Decibel_116
    2,115
    Yes. I should get one. Then I could become a tester/reviewer! Well, not so fast. Then everyone would hate me for being an "objectivist". I've seen it happen before... Naaa. I'll pass. I might could write it off though. Hmmm
    Bill Ferris likes this.
  7. Alobar
    5,856
    SE Alaska
    And in the meanwhile I am looking for a confirmation that my MiniDSP is doing what it says it should, output at up to 24/96.
    I had no reason to wonder until I tried feeding its digital input with the toslink in (instead of analog). I needed a converter to do this so am using this device https://www.minidsp.com/products/usb-audio-interface/usbstreamer-box
    It is set up for 24/96 in and out stereo via firmware patch but when I play the MiniDSP with digital input there is no sound on any music above 4800hz. Fairly certain that it is a driver issue but am just trying to check everything I can think of. If the DSP wont play above 4800, is the fault with it? Or the USB converter or something else completely?
  8. Decibel_116
    2,115
    Have you checked the "advanced" settings in the control panel? You should be able to default to any value the drive will support OR let it adjust based on the source file resolution.
    Alobar likes this.
