Recommends for stylus for Shure M55 cartridge
Discussion in 'Turntables' started by Tucker99, Sep 12, 2017.
  1. Tucker99
    Tucker99 Super Member
    2,329
    West Side, Vancouver, Canada
    Looking for some advice/recommends for stylus for Shure M55 cartridge.
    I have gifted a system to a young woman. Someone gave her a low-mid fi JVC TT and she had no other components to go with it so I set her up with a 35 watt Sansui 1000x receiver and a pair of The Advent. She lives in a wood frame apartment so I built a quick pair of stands to get the speakers off the floor and padded the bottom of the stands with a double layer of those felt floor protector pads.
    The system actually sounded pretty good when I send a digital signal (I used my phone) through the aux input but only fair through the TT and my conclusion is that the cart that was on there was pretty crummy. The TT was a low end model produced when TTs were on the wane and I am sure the cartridge that came with was a cheap a one as they could put on the table.
    Anyhow, on to my query. I have a couple of spare Shure M55 carts in the box but I need styli for them. Jico has an elliptical 'improved' up at $56 and I have read where purchasers seemed to really like it so that may be the best choice but it also the most expensive. I am wondering if there is a lower priced but still decent option either via Amazon or Ebay. I see some listings at varying prices but don't want to buy something low-priced only to discover that it is also low quality. I do want to make a qualitative improvement in her system but want to do so as economically as possible.
    Thanks for your help.
  2. beat_truck
    beat_truck Super Member
    1,924
    SW PA
    schon8624 likes this.
  3. thomo57
    thomo57 Super Member
    2,852
    Sydney, Australia
    I have an M55 set up on one of my turntables and l like it a lot.
    Pretty sure l have a Jico elliptical (not SAS) on it
  4. ivan100000
    ivan100000 Active Member
    408
    California
    I have had Jico, EVG, and of course the OEM Shure N55e; I'd be lying if I said I could tell a difference between them. All sound great. My advice would be to go with the EVG and save all the extra $$ for something else.
    oldman54 and beat_truck like this.
  5. malden
    malden Super Member
    4,948
    The original stylus for the M55E cartridge is the N55E which is a high compliance stylus and for best results should only be mounted in a quality low mass tone-arm.
    A better match for a lower end turntable would probably be a N44-7 or N44E , both of which are medium compliance styli and will work perfectly in the M55E cartridge body.
    N44-7 styli are still produced by Shure but the N44E is not. After-market styli are available in both forms, low cost styli are available on ebay or elsewhere, better quality are available directly from JICO...
    https://www.jico-stylus.com/advance...n_description=1&keywords=shure&sort=2a&page=3
  6. ivan100000
    408
    California
    Malden:
    It seems like all new replacement styli for the N55E are labeled as 759-DE. Would an older original repackaged Shure (i.e; Phanstiehl) that is relabeled as a 759-DE be an N44 or an N55?
  7. malden
    malden Super Member
    4,948
    If it's an original Shure or JICO, then the color of the stylus grip will indicate the model.
    N55E.....yellow
    N44E.....brown
    N44-7....white
    N44G....grey
    N44C.....light blue
    N44-3....green (78's)
    ivan100000 likes this.
  8. twiiii
    twiiii Addicted Member
    5,349
    west Texas
    We found at the radio station beside the fact the N-55E was to fragile that it had a very resonate high end that would give the D-essers fits, so we went back Stanton 500 series, Whats a D-esser. If you push a compressor or limiter or combo to hard you end up with a signal that over emphasizes higher frequencies which transmitters and the link between the studio and the transmitter don't like either. High freq distortion is the last thing you want in broadcasting. So either the compressor had a circuit to suppress these higher frequency modulations or a separate piece was added.
    We don't have that issue at home because most of us have ample headroom and we don't use compressors. But still the idea of cartridge with a resonant high end is one of my pet peeves. So be it Shure, AT, Pickering, London, Ortofon, or some B&O mmc, to name a few, resonant anything is a big no no for me. early tweeters with metal resonating diaphragms are an issue for me, too. All you need is a V-15 1 or II and a Apogee paneled speaker and I am ready to head for the hills. Some of the early JBL with the bullet ring radiator I hated to install. I would have to get away from any loud sounds for the rest of the day it bothered my ears, so. Early FM tuners with leaky pilot signal drove me crazy. Fortunately I can only hear to 17 kHz anymore. Older TV's with their horizontal circuits screaming were an issue for me to.
  9. ivan100000
    408
    California
    So I can assume with a fair degree of certainty that this yellow stylus grip will be an N55E, correct?
  10. malden
    malden Super Member
    4,948
    ...wait a minute, the stylus grip is yellow indicating the N55E, but the package indicates a N44E, 1-3/4 to 4 grams tracking and .4 x .7 mil tip
    ...the N55E has a .2 x .7 mil tip and tracks between 3/4 and 2 grams.
  11. ivan100000
    408
    California
    Somehow I knew it was too good to be true. I should have the sense by now to stick with JICO.
  12. malden
    malden Super Member
    4,948
    so someone slipped a cheap evg into that zenith box?
  13. revox-b77
    revox-b77 AK Subscriber Subscriber
    2,745
    Fingerlakes, NY
    759-DE code comes up as Shure N44E stylus. Just also happens to fit M55 body.
  14. sberger
    sberger Hard Core Geezer Subscriber
    The 44E is a very good stylus. Less chance of mistracking then with the 55E.
  15. sberger
    Wouldn't surprise me.
  16. ivan100000
    408
    California
    Gentlemen:
    I came across a box full of NOS Shure & Pickering styli in Zenith packaging; my plan is to keep the few I can use for my two tables and pass the rest along. As I mentioned above in the thread, there is a 759-DE which I had believed to be yellow, but once it arrived, I saw that it is in fact a white N44-7. The cart on my ELAC Miracord is an M55E that I see can accommodate the N44-7. Would those of you with experience advise that I keep this genuine Shure N44-7 to use along with my M55E cart (that currently holds an N55E stylus)?
    Thanks.
  17. sberger
    Yes, keep the 44-7. It's an excellent stylus for all records, but particularly for older lp's and 45's.
    beat_truck likes this.
  18. oldman54
    oldman54 New Member
    45
    long beach,ca
    To add to the confusion, I have a EVG 759de with brown grip and it just says 2 grams. It's 4x7 also. From Anderson music on fleabay. Sounds great, I've never heard a stock m44e.I have a jico m44g coming from Germany, I hope it's not an EVG made in their factory as I've heard they aren't as good. It cost less than a shure stylus and nobody else makes an aftermarket m44g. I have a newish 447 but it doesn't track as well as my sc35c but I'm looking for a lighter tracker.
  19. Empireman
    Empireman Active Member
    152
    I have one of these on my later body black M55E and it sounds and tracks very good. I also have a Shure NOS that I haven't used yet, because this cheap EVG one sounds so good.
    https://www.ebay.com/itm/253474939581
  20. malden
    malden Super Member
    4,948
    Yes, the N44-7 is a better choice for the Elac than the N55E. The N55E would be better suited for lighter tone-arms.
    KentTeffeteller likes this.
