I never had to replace the dust caps, just move the cone up and down and listen for rubbing. The dust cover protects the voice coil, and the speaker cone moves up and down the voice coil, so if you center the cone, push it , up and down, you should hear no rubbing, make sure you apply pressure evenly, make the speaker move like it was getting bass. Mine worked out perfect and i can not build a model airplane. I did hear that it is hard with speakers that have really tight fitting voice coils but mine certainly did not fall into that type. You will be happy with your results.
