Ren 80s - broken shorting strap
Discussion in 'Infinity Loudspeakers' started by slackie911, Jul 28, 2018.
  1. slackie911
    slackie911 Member
    56
    Hey guys,
    So I recently moved houses and in the moving process the "shorting strap" that the previous owner of my Ren 80s had on, broke. You can see the photo here:
    https://imgur.com/a/ZktfwWq
    Question is, what the heck do I do? Not sure if I can just connect the speakers to my amp (aragon 4004) without and I don't want to try and risk any damage.
  2. swechsler
    swechsler Frog Whisperer
    5,398
    7th row center
    Get another piece of wire, strip both ends, and attach to the binding posts as the old one was. There's nothing special about these straps.
    Celt likes this.
  3. slackie911
    slackie911 Member
    56
    Thanks swechsler
  4. BobbyBluz
    BobbyBluz Well-Known Member
    933
    With the proper tools & skill you can solder it back together. May not look perfect like new but will never break again.
  5. swechsler
    5,398
    7th row center
    That looks like solid brass, in theory it could work. Can't hurt to try certainly.
    OP, use a needlenose pliers to pull the stub from the old strap out of the binding post, then you can see if it's solderable. Of course, soundwise, I sincerely doubt you'd hear a difference.
  6. BobbyBluz
    933
    Actually I'd use a utility knife or Dremel tool to cut around 1/8" off the top of the bottom broken post to give access for soldering. Flux it up, use a solder station with a small chisel tip on high heat then hit it quickly to avoid melting anything if possible.
  7. 7.62
    7.62 Gearhead Subscriber
    1,759
    Las Vegas
    I agree with sweshler, those don't look like the factory post to me. I'd just strip the bottom wire on each side and secure in the binding hole like the top one.
  8. tubed
    tubed Lunatic Member
    16,074
    Aztlan
    If the straps are brass, brass has terrible conductivity compared to copper.
    Only 28% of copper.
  9. jazzmans
    jazzmans Super Member
    2,457
    devils playground, NV
    yeah, those posts and the jumpers are not stock.
    op, just unscrew the broken post completely, then punch the broken bit out with an awl, if it sticks in the speaker-side connecter, get a pair of vise-grips (you can get tiny ones if you need them for 3$ at home depot) and pull it out.
    then just use new wire to jump.
    Originally, it was a flat bar.
  10. slackie911
    slackie911 Member
    56
    Thanks everyone, I used some needle nosed pliars to pull out the old plug, stripped the wires, and use it to make the connection. Cheers!
  11. uvafan420
    uvafan420 LiKe It LoUd
    315
    Yes, those certainly are not stock.
