Repairing cracked Infinity 8" IMG woofer cones
Discussion in 'Infinity Loudspeakers' started by shnaggle, May 11, 2018.
Tags:
  1. shnaggle
    shnaggle Member
    73
    One of my Kappa 6.1 woofers has two cracks in its cone, each about 1.5" long. One of the cracks extends into the silicon surround and adjacent foam. So this crack is one long line from the cone through to the surround foam. I'm considering applying a paper bag "backpatch" for each crack, something I've done for JBL woofer cones with success, but the Kappa cones are a graphite material (and a tiny part of the surround) not paper-type material like a JBL's.
    Would this kind of repair for an IMG cone be sufficient, or should I hunt around for another woofer?.
  2. swechsler
    swechsler Frog Whisperer
    5,509
    7th row center
    I'd probably just replace, I've gotten a pair of these off eBay for under $50 shipped.
  3. shnaggle
    shnaggle Member
    73
    My woofer is #902-6194. Are there are other IMG 8" woofers that are compatible with Kappa 6.1 series II?
  4. chef free
    chef free AK Subscriber Subscriber
    2,298
    Hayward, Ca
    Patches can add enough mass to change the parameters of the speaker, better off with a replacement.
  5. swechsler
    5,509
    7th row center
    AFAIK that's the only one that will work properly. There are enough of those around that they come up for sale fairly often.
  6. Bobbyd38
    Bobbyd38 AVA • American Vintage Audio Subscriber
    141
    MA
    A small thin bead of Black Speaker adhesive on the Back side of the crack will fix it.
