Replacement capacitors + id component
Discussion in 'DIY' started by Atv023, Jul 14, 2017.
  1. Atv023
    Atv023 New Member
    36
    Can anyone suggest some good types of capacitors for a crossover?
    Also, does anyone know what the smaller capacitor is that is perpendicular to the two larger ones on each side? It is only labeled 5\100v.
    Some audio capacitor brands I've seen are siemens mkl, roederstein, BC Philips, Vishay.....
  2. elnaldo
    elnaldo Addicted Member
    6,896
    Buenos Aires GMT-3
    5/100V should be 5uF 100V.
    Depending on your budget, you can get any film capacitor to replace the smaller ones (polypropylene are preferred over polyester, but both are suitable replacements). The 47uF, if film, will be quite large, and a bit expensive. I'd get a non polarized (or "bi-polar") electrolytic for that one. Non polarized electrolytic are much cheaper than film caps, you can get all 3 electrolytics if budget is an issue.
    Dayton and Solen are known as very good caps for a good price. Bennic is also a known brand for crossover electrolytics. Nichicon "ES" series are also non polaryzed electrolytics. Search the web and the AK sponsors to see where you can buy them. I've got parts from partsconnexion (NO AFFILIATION) due cheaper shipping rates to south america. But a lot of people buy from parts express (NO AFFILIATION) or from local dealers.
    You can even use regular motor run capacitors if the uF is the same. They are usually very good industrial quality caps.
    NO AFFILIATION: https://solen.ca/product-category/capacitors/dayton-metallized-polypropylene-capacitors/page/2/
    NO AFFILIATION: http://www.partsconnexion.com/capacitor_ele_nichicon_es.html
    http://www.partsconnexion.com/capacitor_ele_nichicon_dbgb.html
  3. gadget73
    34,913
    Southern NJ
    All of what he said. Film if you can fit and afford, BP electrolytic if not. Most of the time the big ones will be in parallel with the woofer circuit, so slightly less critical (IMO) than the smaller values in series with the tweeter and/or midrange.
  4. deltalight
    deltalight AK Subscriber Subscriber
    234
    Minneapolis
    4.7uF 450v PP 5% 25.3x11.7x22.5mm(leadspace): 667-ECW-FD2W475J
  5. Atv023
    Atv023 New Member
    36
    All the caps now are polarized electrolytic. Does it matter if they are non-polarized?
    I don't know much about crossovers or how they work.
  6. BinaryMike
    BinaryMike Pelagic EE Subscriber
    Electrolytic caps for crossover use MUST be non-polarized.
  7. Atv023
    Atv023 New Member
    36
    Here is a circuit diagram of the crossover. Best I could do.
  8. elnaldo
    6,896
    Buenos Aires GMT-3
    this is a clearer way to draw what you have :
    As said, use non polarized electrolytic for crossovers, or film caps. I'd use film for the tweeter, even cheap polyester caps, those generic reddish brown. You can parallel capacitors to achieve a certain value, perhaps 4.7 in parallel with 0.22 or 0.33 to get closer to 5uF (even if I think you won't notice any difference between 4.7 or 5uF). Or, 6.8 in parallel with 3.3 to get 10 uF. Or, 2 x 4,7 will be 9.4, close enough to 10uF.
    Atv023 likes this.
  9. gadget73
    34,913
    Southern NJ
    A lot of lesser speakers did use polarized. NP are what really should go there.
