I've narrowed down my search to the following two Nichicon caps:
LGU1J103MELC.......$5.54...10,000uF...63V...105 deg...3,000 hrs...4.69A @ 120Hz, 5.3935A @ 50kHz ripple current...Total cost: $44.32
LGY1J103MELC50...$7.89...10,000uF...63V...105 deg...5,000 hrs...3.8A @ 120Hz, 4.37A @ 50kHz ripple current...Total cost: $63.12
Dimensions are the same, 35 X 52 mm. If you had to choose between the two, which would you choose?
