I have used the MY2-02-DC24 Relay in 2245’s with no issues.Edit ^ N8Nagel answered it as I was typing ^
The correct relay replacement for a 2250B from Mouser is 653-MY2-02-DC2.
https://www.mouser.com/ProductDetail/Omron-Automation-and-Safety/MY2-02-DC24?qs=/ha2pyFadujG/ksi5EsGkscB3VOpe3F/q6FxzF3Hufiyba4Bn%2bNwvA==
(The pin configuration on 2245/2270 relays are slightly different allowing for wires to be soldered to them.)
Yes, that relay will work fine in these receivers.I have used the MY2-02-DC24 Relay in 2245’s with no issues.
The 2245/2270 Relay is MY2 DC24 Mouser Part Number: 653-MY2K-02-DC24
Thanks so much for that clarification! That helps me a lot and i’m sure others for future ordering.To clarify my previous comment, 2245/2270s use MY2 DC24 relays but the relays are mounted slightly differently on the boards and this relay won't directly fit the 2250B.
According to the spec sheet on PN 653-MY2K-02-DC24 version that you mentioned has 2.6mm wide solder pins w/o holes which will fit 2245/2270 receivers.
PN 653-MY2-02-DC24 (non-K), that I linked to above, has 1mm wide solder pins.
So the difference between these two relays is the width of pins - the 2250B uses the relay with the smaller pins to fit the board
that will mostly likely be a shorted component . quite possibly an output device or power supply rectifier .OK I will do that but i do not think that is my problem right now i have to figure out why i am getting that very bright light on my DBT
Is this the correct relay? MY2-DC24-S? I can't find one with the MY2-02-24-S
https://www.digikey.com/product-detail/en/omron-automation-and-safety/MY2-DC24-S/Z182-ND/307700
In fact, I can't find the (S) model with the -02- designation (PCB pins).
The link you posted is the proper relay for 2245s and 2270s. It has .5mm x 2.6mm tabs with holes to solder the additional wires to.
MY2-02-DC24 has .5 x1mm pins suitable for soldering directly to PCB boards on later models using the MY2 relays such as the 2250B.
