Hi folks, my SX-737 is opened up and I replaced the seven fuse lamps with LEDs. No issues there. I also have LED bulbs to replace the indicator lamps, but I'm not certain about the best approach. To do this, it appears I'd have to unwrap the existing indicator bulb wires from the pins (where they were wrapped tightly with a special tool instead of soldering), and then solder on the leads of the new bulbs. Is it better to just snip the existing wires and solder them to the leads of my new LED bulbs, thereby keeping the wrapping intact on the pins?
