luminophor
New Member
Has anyone ever replaced their Infinity Column II feet? I'm in the middle of a restoration on a pair that were stored in a garage for twenty years, and a couple of the particle board feet are dissolving on the edges, making the speakers kind of unsteady.
I can't tell if the feet are built into the cabinet itself, or just into the bottom portion of the frame, that holds the down firing woofer, and I'm not sure what the best way to proceed with removing and replacing them is. I wanted to remove the feet and replace them with four adjustable height feet, but not knowing how much material there is to screw into or what part of the cabinet will be bearing the load, I'm not sure if that would work.
So far my best idea is to build a little frame around the feet, with stronger wood, to brace them up. Has anyone replaced the feet on their cabs? Do you have a better suggestion for me?
Thanks!
Thanks!
