Nope. The intent of the resistors is to limit the voltage from the silicon rectifier + resistor combination to that which was emitted by the original selenium rectifier, which has a higher voltage drop than a silicon rectifier.
yeah what he said.
somewhere, there is on the schematic the path where you get your plate voltages (the top 'line' of the tube in the SCM). still being ignorant of the 300, in my tube radios this figure is 90% of the time between 90-110v.
now depending on how old the set is it is based on: RMS of AC line voltage, half or full wave, smoothed by a cap then minus some voltage drop of a resistor.
the (typical) 22ohm inrush limiting resistor was place in front of the se rect to impede current heading to that discharged cap, which appears as a dead short. the cap would survive, the Se rect would not. since the rectifier on my sets was in the 100ma range, any modern 1A silicon diode with an 'x' amp surge, will handle it, BUT, the inrush acted in concert with the natural resistance of the Se rect to give 'some' output.. at any rate, 2 things work against you,
a) silicon has far less resistance and a very low voltage drop and
b) line voltage today sits around 125 when typically in the past it was 117. so not only do we worry about the extra 8 volts scurrying across the heater string, it throws the plate voltage off.
empirically I found that 120-150 ohms in huge watt numbers (10) take the place of the inrush plus the Se rect internal resistances. YMMV
on the fisher board, those guys are fairly obsessed any might have the parts subs already at hand.
and one last, if not replaced, your main filter cap, which may or maynot be multi sections or multi discreet units, tended to sit around 150wv. with everything I have found today 160v stuff is the lowest I would use, 200v might even be safer.
consult your schematic.
and unlike amps where guys drive plate voltage to lethal limits (for both humans and tubes) in the FM section, such behaviour might not be optimum
