Gobstopper
Hi everyone, brief question, I'm replacing the outputs transistors on my SA-7100(going with MJ2119XG for the 2sd and 2sbs as suggested) In any event, I hadn't run across any mentions of "WATCH PIN OUT" in the BOMs on this forum that I've seen from time to time for 3 leg transistors, but thought to double check. I compared the pinout for the 2sd371 that I found online against the datasheet for the MJ21194. I went in assuming the pinouts were the same, but don't know based on the sheets if they actually are; there doesn't seem to a clear reference point like on the other 3 lead transistors. Can anyone confirm that I should match the pins (slightly above the midline) between the two sets? It's possible they only go in one way, but just wanted to double check before screwing anything up.
Thanks
Thanks
