Harolda
Well-Known Member
After finishing my second TA-N7B i want to start on restoration works on my AU X1.
The unit has been serviced by a so called specialist on vintage HIFI in Germany "Good Old Hifi" about two years ago, but i do not want you to show the work he did. After i received the unit back it did work for some time, but it after a few weeks it quickly went into protection when using the AUX and TUNER input or i had a large amount of hum.
Then i did not use it for a long time and wondered what to do with it. Now i decided it is time to get the unit to the best condition possible.
This week i took out all the phono boards and the hum and instability is gone. I listened to it for some time and it seems to be Ok. I decided to check the unit further. What i found noticed thus far:
1) Almost all black flags have been removed, except for the ones on the left power amp board (F-2775).
2) Only 2 electric capacitors have been replaced, but i would like to do a complete recap
3) Relays were all replaced, also the small ones on the Phono master PCB
4) No new trim pots
5) two resistors replaced
6) The Phono master PCB seems to be of the old type, but i noticed that some PCB tracks have been cut by the repair shop.
7) One of the power resistors of the left power amp was not even connected to one of the transistors
8) The biggest surprise was that the original 2SA1068N and 2SC2493N have been replaced by 2SA1117 and 2SC2608 on both channels. But that could be from an older service job.
Finding the original replacements is nearly impossible as you all know, but i can get the 2SA1068 units, but not the N types. I did not yet find a source for the 2SC2493(N) units.
I read some threads on replacements for the high speeds Sanken's and it seems that there are only suitable replacements from STM are 2ST2121 and 2ST5949 both 25Mhz. Has anyone experience with using these as replacements? Or should i stay with the 2SA1117/2SC2608 units which are 20Mhz.
regards,
4) No new trim pots
regards,
