    Dismiss Notice
Revox A77 rewind problem.
Discussion in 'Tape' started by MickeySmile, Sep 11, 2018.
  1. MickeySmile
    MickeySmile Well-Known Member
    681
    Sugar land, Texas
    I just finished recap on the 2nd Revox A77 mk IV. It had smoke motor caps problem before the recap job.
    Without tape, I press and hold the play button, only the right motor ( take up reel) is spinning. Could someone help me to solve this problem. Thanking in advance for help!
    Binh
  2. tapetech
    tapetech Repair Professional
    With no tape, what happens when you press rewind?
    If nothing, clean the transport relay contacts.
  3. MickeySmile
    681
    Sugar land, Texas
    All the relay contacts have been cleaned. With no tape, when I press rewind button no movement on the rewind motor, very slowly move on take up reel motor with the same play direction.
  4. tapetech
    Be sure the "no movement" defect isn't caused by the left brake being engaged. Brake should be released in REW.
    Test/clean the reel motor on/off switch. Check that R125 is 1.2K ohms.
    If those items are good, you perhaps made a mistake somewhere when you recapped. Check that all wires go where they are supposed to go and that all caps are correct value and have correct polarity.
  5. MickeySmile
    681
    Sugar land, Texas
    Problem solved. :banana: I did make a mistake 2 green wires on control board( 1 from motor and 1 from the capacitor for the motor). After swapping them everything work correctly. Thank you Tapetech for advicing me!
