perryinva
IS it vintage????
I have a few quick questions mainly for Steerpike and Marc, I guess about the B710MKII: the pressure rollers, the heads, and the capstan motor assembly. After much hair pulling and diagnostics on the pair of B710MKII's I've been working on, one serial number 16xxx, the other 13xxx, which puts them both well below the last revision of the deck, which was around 20xxx, I've got them "working".
The newer deck 16xxx, had been poorly worked on by a previous owner, that replaced all the electrolytics & tantalums with either Nichicon ES, or with what appear to be Wima polypropylenes (up to 4.7uF!). He also replaced any small electrolytic caps with Wima polypropylenes. He used mostly Nichicon ES and FG caps in the "normal" sizes. Nice caps to use, for sure, and many old 4559s were replaced with 2134s, as well. However, he lifted & tore many traces which I have repaired, and it, along with the other deck, which appeared factory untouched, are both now re-capped and socketed.
Both decks have nasty pressure rollers. Both so soft/rotted, that I can easily pull a piece of the rubber off with a finger nail. The 16XXX deck has a like new Sony RPS202-3602A head set, and both pressure rollers are the exact same size, while the 13xxx has a larger take-up roller and smaller supply, and a different looking Sony head set, (some face wear and staining evident, but not bad at all really) but with the exact same model numbers. Everything else on the transports is identical. The larger rollers on both decks are ~9mm in diameter and the smaller is ~8mm. The SM shows two different part numbers for rollers on MKI and 1st Gen MKII for supply (#201) and TU (#202). The last Gen MKII shows the same part number for both two (#203) rollers. Since I have to have all 4 re-rubbered by Terry Witt, I can't think of any reason for not making them all 9mm, can you? Both decks have the exact same symptoms, horrible W&F in the .3-.4% range, with tape speed starting at say 3000Hz, and steadily dropping to around 2930Hz as the take-up spool enlarges. I'm assuming this is a result of the shot rollers. I've rebuilt, cleaned and lubed the one decks capstan motors, applying JUST enough torque to the motor PCB fixing screws, (loctite on the screws) to minimize friction on the capstan shafts. I found out very fast that too much tightening increased the friction on the shafts so much that the motors would not even turn them. It is not obvious to me why, though. Still exhibits the same conditions, which is similar to, though much worse, than the B215s I've worked on, which, once the rollers were re-rubbered, function perfectly and well under spec. Make sense to you? Any hints or tips I need to look out for on the motor rebuilds? Seemed very straightforward to me. All 4 reel motors are strong and quiet, so I just lubed the front bearing on each with PDP-65.
The heads on the newer deck are a bit shorter, about 9mm in height, vs 10mm on the older one, with a different head block mounting design, but such that the gap side is the same distance for stroke when mounted. The newer one had ty-raps at various points on the cables, while the older deck had only one at either connector. Do you think this a normal variation in production changes? Or is it likely that the newer deck had the heads replaced with last gen ones, which requires a few EQ mods? Any ideas? Should I look for a better head set?
Thanks, guys!
Thanks, guys!
