Got a Revox B77. Had it running, playing & recording. Record lamps worked. Meter lamps were out, then one lamp flickered in and out. So I pulled the panel to get to the meters. Pulled the meters to get at the lamps. the one that flickered did light but would not stay lit. So I was going to order bulbs. Put it back together. Put a tape on to check functions while I had cover off. Will FF & RWD. But would not run in play. Then I noticed the capstan was not spinning. I spun the motor bay hand and it spun. Engaged play and it stopped. Spun it again with power on and kept spinning slow, seemed to be getting some voltage. Shut off power and it stopped. The record lamps won't come on now ether. What gives, Did I F*** something up messing with the meters?
