Are those mass loaded TQWT's a la Bob Brines? Do you like the sound?
Yes sir they are TQWT's a la Bob Brines and it was your speakers that first caught my eye for the project. I used .5 MDF and I like the sound but the highs are a little harsh at times… I will do the cotton ball mod to the whizzer as that appears to help a little. I got this mod from the Lowther page. Info below
Without going into the technical mumbo-jumbo, one of the things that occurs with the old style Lowther cones is that the whizzer resonated at about 2 KHz, creating what many referred to as the Lowther shout. This has been addressed by the new cone design, but since few of you have the new cone design, lets talk about what can be done.
The easiest thing to do is to turn the drivers so that they face 15 to 20 degrees away from your listening position.
I personally tried and liked the effect of Marc Wauters 98 cent fix. This consists of placing a lightweight piece of foam between the outer edge of the whizzer and the middle of the main cone. As a result, it drastically reduced the resonance peak of the whizzer. I strongly suggest you visit Marc's web page to catch the detail on this.
Another approach is to take 2 cotton balls for each driver. Pull them out, and then twist lightly so that you get a 2 or 3 inch long cylinder. Then place this between the whizzer and main cone. It is not as effective as the Marc Wauters fix, but does create a noticeable drop in the upper midrange peak.
You can purchase the new style phase plug without upgrading the cone. It does make the highs very directional, so that you must listen with the speakers aimed directly in line with your ears.
Did you happen to try the drivers without damping?
Yes I did and it appears to give it a tighter feel in the lower mid rang area. It allows the speaker to give a little more pronounce pouch.. If that makes any scenes.
I always add damping if the speaker frame is cheap or weak.. It cant hurt right?
One last question: did you build a BSC filter?
No I did not but now that I know about it I my have to try it.
Oh, BTW, your cabinets are VERY nice looking!
Thank you very much!
They are not as red as they look in the photo and they are more burgundy than red. I applied 5 coats of paint and with very coat I ran over it with a wire roller which gives it a nice texture look.
