thattreeguy
New Member
Hey Audiokarma.
The tonearm on my newly acquired Sansui SR 525 (awesome sounding turntable!) would swing outward whenever I put the cart over the record and let go. Turns out the little rubber piece on the arm lifter had gone bad and the rubber was no longer tachy allowing the tonearm to slide right across it. I cleaned the rubber piece with a product by MG Chemicals called Rubber Renue and it made a world of difference. The arm more or less stays put now.
I was wondering if anyone out there has used this product on vintage audio gear? Specifically I would like to know if it would be beneficial and safe to use Rubber Renue (or similar product) to clean a turntable belt? What about the rubber surrounds on a speaker woofer? A rubber platter mat? Has anyone had good results? Does anyone out there think this would be a bad idea?
Thank you!
Analogue is King!!
Thank you!
Analogue is King!!
