Run two dacs simutaneously on Windows PC?
Discussion in 'DACs' started by Aleksei77, Nov 9, 2018.
  1. Aleksei77
    Aleksei77 Member
    66
    Can this is possible, im trying to figure how to do it, treid stereo mix in sounds dispositives with no sucess
  2. reggiesanche
    reggiesanche AK Subscriber Subscriber
    400
    Medford , OR
    I'm not sure if it's possible or not, but I would wager that you would get much better results if you split the signal on the analog side of things.
  3. wyn palmer
    wyn palmer Active Member
    489
    I'm not sure that I understand the question. Could you please explain in more detail.
    External stereo DACs can be used via USB on Windows 10. Generally they would come with a Microsoft certified driver that configures them and provides a user interface.
    There are many examples of this.
  4. SaSi
    SaSi Seriously Illogical Subscriber
    4,180
    Athens, Greece
    Not sure if it's possible with XP but with Win7, I've done that, using both the internal DAC and an external USB (Focusrite) DAC. It's a bit involved as you need to assign one of the sound applications to a specific DAC, which I was able to do with Audition (and Cool Edit Pro) leaving normal media player applications using the default output. Should be the same with Windows 10.
  5. Aleksei77
    Aleksei77 Member
    66
    the same music playing on my asio focusrite interface and my dac meridian explorer in the same time
  6. cpt_paranoia
    cpt_paranoia Super Member
    1,086
    Why?
    The only reason I can think of is to do A/B comparison.
    AlTinkster92 and imral3 like this.
