Rust on Ortofon RMG 212 - Reblue ?
Discussion in 'Turntables' started by klipschbro, Nov 30, 2018.
  1. klipschbro
    klipschbro New Member
    18
    Just picked up an Ortofon RMG 212. There is a rust spot on the counterweight. Has anyone refinished theirs?
    Is the counterweight Brass or Bronze?
    Has anyone sent theirs out to get hot blued?
    It looks like I can remove the blueing with white vinegar, scotch brite the rust and re-blue with either of these solutions:
    BROWNELLS - OXPHO-BLUE® CREME
    Birchwood Casey Brass Black
    https://www.firearmstalk.com/threads/using-gun-bluing-on-brass-w-pics.105816/
  2. Freddymac2
    Freddymac2 Super Member
    1,906
    Is that arm a 16" monster? What cartridge do you run on that? I do not think a blueing for brass will work on steel. The cold blueing's I have used, did not hold up under use for very long, and they were never even close to hot blueing.
  3. klipschbro
    18
    This is the 9" arm. The 12" is the RMG 309. I am currently running an Ortofon SPU headshell with an Ortofon F15E. A total mismatch on compliance. Shopping around for an Ortofon SPU and SUT. Maybe I will just send it away for hot blueing. I am unsure if its brass or bronze, it definitely is not steel.
  4. Freddymac2
    1,906
    I have a RMG 309 on my bench, I will have to look at it more closely. Bronze does not rust, so it is on the surface only.
  5. totem
    totem AK Subscriber Subscriber
    5,416
    Vancouver Island
    Have an RMG-212 that has a tiny spot or two of discolouration but not as noticeable
    as on your counter weight.
    That set screw within a set screw on the counter weight was an Ortofon tradition and the reason
    the shafts get all marked up from unknowing users.
  6. klipschbro
    18
    The 2 screws almost got me. While going over the tonearm, I removed the counterweight. I was definitely the first one to do that, as there was only one mark on the shaft from the set screw.
  7. klipschbro
    18
    I'm going to try to cold blue it. Does anyone know how to separate the pieces of the counterweight?
  8. klipschbro
    18
    The brass screw does not seem to do anything, and the only photos of the thing disassembled was on www.goldenageaudio.com.au. which is now offline.
  9. totem
    5,416
    Vancouver Island
    Off the top of my head I thought the bottom knurled ring unscrews?
  10. klipschbro
    18
    Does not seem to budge and I do not want to force it.
  11. klipschbro
    18
    I found the photo via wayback machine. It does look like the owner of Golden Age Audio passed.
  12. klipschbro
    18
  13. klipschbro
    18
    I got it! Brass screw counter clockwise. It took a little force to crack. I will be re-blueing soon and will update with the results.
    Grbluen likes this.
  14. cafe latte
    cafe latte AK Subscriber Subscriber
    819
    Ravenshoe
    Cold blue get it de greased and hot ie boiling water and cold blue can look amazing. On a gun it wont be as resistant (cold blue) but a counter weight on a turntable that lives in the house just cold blue will be fine if done correctly.
    Chris
    klipschbro likes this.
  15. klipschbro
    18
    After soak in white vinegar and polished with 0000 steel wool.
    Grbluen likes this.
  16. klipschbro
    18
    This is the result of the creme. Brass black was not much better. Back to brass. I will probably send it away to get hot blued.
  17. cafe latte
    819
    Ravenshoe
    Google it, it is not hard to do hot bluing yourself.
    Chris
  18. klipschbro
    18
    I will never have to use the process for anything else in my life, ever. It will be cheaper to have someone else do it.
