What could be done about a RX-V1 with a supposed bad DSP? Any thoughts?
D drumbum Super Member Dec 29, 2017 #1 What could be done about a RX-V1 with a supposed bad DSP? Any thoughts?
Raynald Addicted Member Dec 29, 2017 #2 Does it work with effect off? If so you have a very nice stereo receiver. If not, without any work you could still have a remote controlled tuner via tape out and three very nice power amps via Main and Center In.
D drumbum Super Member Dec 29, 2017 #3 I know where one is with a supposed bad DSP chip. I might try to get it.
Raynald Addicted Member Dec 29, 2017 #4 Try it in Processor Direct mode, push button under the front panel flap. That might bypass the DSP which is how I almost always use mine.
D drumbum Super Member Feb 22, 2018 #6 RX-V1 resides with me now. Suffice to say it wouldn't sing in it's original form. Plans are to make use of the beef. 27,000uf 71v filter caps and a 15# transformer. This will be a puzzle, but the plan is a stand alone 6 ch. amplifier.
Mrv8q Audiofool Feb 22, 2018 #7 Nice! So are you going to go the pre out, main in route? I use my RX-V3000 in analog mode only, and am very happy with it, used as an overkill garage receiver.
D drumbum Super Member Mar 4, 2018 #8 Mrv8q said: Nice! So are you going to go the pre out, main in route? I use my RX-V3000 in analog mode only, and am very happy with it, used as an overkill garage receiver. Click to expand... Yep. Just need to decide how I may use it. One set of in's for 6 ch. stereo, or 6 discrete in's.
