SA-1000 Cap List for Vetting.
Discussion in 'Pioneer Audio' started by larryderouin, Sep 29, 2013.
  1. larryderouin
    22,227
    Glen Burnie Md.
    FINAL LIST IS IN POST #10. DO NOT USE LIST IN POST #1.
    This is the companion list to the SA-1000 Transistor list.
    there are a couple of parts I wasn't sure on or couldn't xref, so left them blank. Both are DIODE Numbers.
    THIS LIST IS PRELIMINARY USE FINAL LIST IN POST #10
    ALL PART #'s are MOUSER and in stock as of 29SEPT 2013. Prices are current as of that date.
    There are a couple of parts I couldn't XREF. UNTIL THEY ARE, This is STILL A Preliminary List.
    The VALUE/VOLTS on any cap after the price is the replacement cap values.
    SA-1000 Capacitor's, Diodes
    POWER SUPPLY (W16-035)
    C2 1000uf 10V CEA UPW 647-UPW1E102MHD...$.49
    C3 100uf/50V CEA ... UPW 647-UPW1H101MPD...$.41
    C4 100uf/50V CEA ... UPW 647-UPW1H101MPD...$.41
    C5 100uf/50V CEA ... UPW 647-UPW1H101MPD...$.41
    C6 100uf/50V CEA ... UPW 647-UPW1H101MPD ..$.41
    C8 220uf 35V CEA ... UPW 647-UPW1V221MPD ..$.39
    D1 SR3AM -> 1n5406 512-1N5406.........................$.51
    D2 SR3AM -> 1n5406 512-1N5406.........................$.51
    D3 SR3AM -> 1n5406 512-1N5406 ........................$.51
    D4 SR3AM -> 1n5406 512-1N5406 ........................$.51
    D5 FR2-02 -> 1n4007 512-1N4007........................$.14
    D6 1S1850 ->
    D7 WZ-130 13V/0.5W ZENER -> 512-1n5243b ......$.12
    HEAD AMP (W21-007)
    C1 1uf/25V CSSA ... 667-ECQ-V1H105JL3.......$.68 1uf/50V
    C2 1uf/25V CSSA ... 667-ECQ-V1H105JL3........$.68 1uf/50V
    C3 4.7uf/25v CEA ... 647-UKL1E4R7KDD...........$.15
    C4 4.7uf 25V CEA ... 647-UKL1E4R7KDD...........$.15
    C5 10uf /25V CEA ... 647-UKL1E100KDDANA ..$.37
    C6 10uf/25V CEA ... 647-UKL1E100KDDANA ..$.37
    C15 100uf/35V CEA .. 647-UKL1V101KPDANA ..$.64
    CONTROL AMP (W15-050)
    C3 30uf/6V CEA ................. 647-UKL1C330KDDANA $.35 33uf/16V
    C4 30uf/6V CEA ................. 647-UKL1C330KDDANA..$.35 33uf/16V
    C7 4.7uf 25V CEA ............. 647-UKL1E4R7KDD .......$.15
    C8 4.7uf/25V CEA ............. 647-UKL1E4R7KDD .......$.15
    C11 10uf/ 25V CEA ........... 647-UKL1E100KDDANA $.37
    C12 10uf/ 25V CEA .......... 647-UKL1E100KDDANA $.37
    C13 10uf/ 25V CEA ......... 647-UKL1E100KDDANA $.37
    C14 10uf/ 25V CEA ......... 647-UKL1E100KDDANA $.37
    C25 220uf/35V CEA ........ 647-UKL1V221KPD.......... $.77 220uf/35V
    FILTER UNIT (W28-004)
    C9 1uf/25V CEA ......... 667-ECQ-V1H105JL3 ..........$.68
    C10 1uf/25V CEA ....... 667-ECQ-V1H105JL3...........$.68
    C19 10uf/16V CEA ....... 647-UKL1E100KDDANA....$.37
    C20 10uf/16V CEA ........647-UKL1E100KDDANA..$.37
    C25 220uf/25V CEA ...... 647-UKL1V221KPD........ $.77 220uf/35V
    MAIN AMP (W23-008)
    C1 2.2uf/25V CSSA ....... 667-ECQ-V1H225JL............$1.09 2.2uf/50V
    C2 2.2uf/25V CSSA ........667-ECQ-V1H225JL............$1.09 2.2uf/50V
    C5 22uf/6V CEA ............. 647-UKL1C220KDDANA....$.33 22uf/16V
    C6 22uf/6V CEA ..............647-UKL1C220KDDANA ...$.33 22uf/16V
    C11 220uf/10V CEA........647-UKL1V221KPD............$.77 220uf/35V
    C12 220uf/10V CEA .......647-UKL1V221KPD ...........$.77 220uf/35V
    C13 100uf/50V CEA .......647-UKL1H101KPD ...........$.56
    C14 100uf/50V CEA .......647-UKL1H101KPD........... $.56
    D1 WZ-130 (ZENER 13V/ .5W)-> 512-1n5243b .......$.12
    D2 WZ-130 (ZENER 13V/ .5W) -> 512-1n5243b.......$.12
    D3 SH-1S -> 1n4007 ......................512-1N4007.........$.14
    D4 SH-1S -> 1n4007......................512-1N4007.........$.14
    D5 1s1212 -> ????1n4148 or 1n914????
    VR1 4.7K trimmer Top adjust 652-3296W-1-502LF $1.74 5.0K oHm
    VR2 4.7K trimmer Top Adjust 652-3296W-1-502LF $1.74 5.0K oHm
    VR3 1.5K trimmer Top Adjust 652-3296W-1-502LF $1.74 2.0K oHm
    VR4 1.5K trimmer Top Adjust 652-3296W-1-502LF $1.74 2.0K oHm
    PROTECTION UNIT(W28-008)
    C3 220uf/10V CEA 647-UKL1V221KPD .........$.77 220uf/35V
    C4 220uf/10V CEA 647-UKL1V221KPD..........$.77 220uf/35V
    C6 100uf/16V CEA 647-UKL1V101KPDANA ..$.64 100uf/35V
    D1 SIB01 -> 1n4007 512-1N4007 $.14
    D2 SIB01 -> 1n4007 512-1N4007 $.14
    D3 SIB01 -> 1n4007 512-1N4007 $.14
    D4 SIB01 -> 1n4007 512-1N4007 $.14
    D5 SIB01 -> 1n4007 512-1N4007 $.14
    D6 SIB01 -> 1n4007 512-1N4007 $.14
    D7 SIB01 -> 1n4007 512-1N4007 $.14
    D8 VB11-A ????......spec:Mitsubishi GE-ST 10ma, Uf=0.16V(1mA)
    D9 VB11-A ???? Same as D8
    VR1 100ohm trimmer Top adjust......652-3296W-1-101LF.........$1.74
    MISCELLANEOUS PARTS
    Main Filter caps.....
    C33, 4700uf/50V 647-UVZ1H472MRD $3.19
    C34, 4700uf/50V 647-UVZ1H472MRD $3.19
    C35, 4700uf/50V 647-UVZ1H472MRD $3.19
    C36 4700uf/50V 647-UVZ1H472MRD $3.19
    C37 1000uf/63V 647-UPW1J102MHD $2.55
    C38,C39 0.01uf/450VAC 0.01uf/ X-Y rated Safety caps
    C42 47uf/50V CEA AXIAL....647-TVX1H470MAD $.54
    ............................................PRELIMINARY LIST. DO NOT USE.........USE LIST IN POST #10......................................
    When both get vetted I'll clean them up and combine into one and make a BOM.
    Larry
  2. mattsd
    mattsd AK Subscriber Subscriber
    1,673
    Cincinnati, Ohio
    There are several errors in that list, but there's one very obvious oddity I saw. Why in the world are you using UKL low leakage caps for every single one of the CEA labeled caps except the power supply? :scratch2: Those are supposed to be replaced by UPW caps, the other option is Panasonic FM or FC (I prefer the latter, they have better tonal quality when used in the preamp area compared to UPW's). You only need UKL's for CSSA, CSZA and CEANL caps, and if they are 1uF or under, ECQ film caps.
    I'll put up a list here soon, if not tonight tomorrow for sure.
  3. SoundOfSound
    SoundOfSound Super Member
    4,069
  4. larryderouin
    22,227
    Glen Burnie Md.
    Oversimplifying old habit. Power supply UPW's and signal path UKL's, 2.2uf & < ECQ's
    1.) going directly from the manual. No unit to compare with.
    2.) the 1s1212 replacement is a SWAG.
    3.) VB-11 is a germanium diode. Not sure what goes in and couldn't find it via googling the forum. So just put up the specs.
    Let's stick with Nichicon's. I like them and easier for me on the order end.
    thanks
    Larry
  5. mattsd
    1,673
    Cincinnati, Ohio
    Pioneer SA-1000 Recap List
    Here is the list:
    IT IS NOT YET COMPLETE, DO NOT ORDER FROM UNTIL THIS LINE IS GONE.
    Pioneer SA-1000 recap list with diodes, diodes don't have to be replaced.
    Head Amp Board (W21-007)
    W21-007: C1: 1uF 25v CSSA: 667-ECQ-V1H105JL3 1uF 50v
    W21-007: C2: 1uF 25v CSSA: 667-ECQ-V1H105JL3 1uF 50v
    W21-007: C3: 4.7uF 25v CEA: 647-UPW1H4R7MDD 4.7uF 50v
    W21-007: C4: 4.7uF 25v CEA: 647-UPW1H4R7MDD 4.7uF 50v
    W21-007: C5: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
    W21-007: C6: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
    W21-007: C15: 100uF 35v CEA: 647-UPW1H101MPD 100uF 50v
    Control Amp Board (W15-050)
    W15-050: C1: .1uF 25v CQMA (Mylar): 667-ECQ-V1H104JL3 .1uF 50v
    W15-050: C2: .1uF 25v CQMA (Mylar): 667-ECQ-V1H104JL3 .1uF 50v
    W15-050: C3: 30uF 6.3v CEA: 647-UPW1C330MDD 33uF 16v
    W15-050: C4: 30uF 6.3v CEA: 647-UPW1C330MDD 33uF 16v
    W15-050: C7: 4.7uF 25v CEA: 647-UPW1H4R7MDD 4.7uF 50v
    W15-050: C8: 4.7uF 25v CEA: 647-UPW1H4R7MDD 4.7uF 50v
    W15-050: C11: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
    W15-050: C12: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
    W15-050: C13: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
    W15-050: C14: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
    W15-050: C15: 220uF 35v CEA: 647-UPW1H221MPD 220uF 50v
    Filter Board (W28-004)
    W28-004: C9: 1uF 25v CEA: 647-UPW1H010MDD 1uF 50v
    W28-004: C10: 1uF 25v CEA: 647-UPW1H010MDD 1uF 50v
    W28-004: C19: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
    W28-004: C20: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
    W28-004: C25: 220uF 25v CEA: 647-UPW1E221MPD 220uF 25v
    Main Amp Board (W23-008)
    W23-008: C1: 2.2uF 25v CSSA: 647-UKL1H2R2MDDANA 2.2uF 50v
    W23-008: C2: 2.2uF 25v CSSA: 647-UKL1H2R2MDDANA 2.2uF 50v
    W23-008: C5: 22uF 6.3v CEA: 647-UPW1A220MDD 22uF 10v
    W23-008: C6: 22uF 6.3v CEA: 647-UPW1A220MDD 22uF 10v
    W23-008: C11: 220uF 10v CEA: 647-UPW1E221MPD 220uF 25v
    W23-008: C12: 220uF 10v CEA: 647-UPW1E221MPD 220uF 25v
    W23-008: C13: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
    W23-008: C14: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
    VR1: 4.7K ohm multi offset: 652-3296Y-1-502LF 5K ohm 25 turn
    VR2: 4.7K ohm multi offset: 652-3296Y-1-502LF 5K ohm 25 turn
    VR3: 1.5K ohm single bias: 652-3386F-1-202LF 2K ohm single turn
    VR4: 1.5K ohm single bias: 652-3386F-1-202LF 2K ohm single turn
    D1: WZ-130: 512-1N5243B
    D2: WZ-130: 512-1N5243B
    D5: 1S1212: 512-1N4148
    Protection Board (W28-008)
    W28-008: C3: 220uF 10v CEA: 647-UPW1E221MPD 220uF 25v
    W28-008: C4: 220uF 10v CEA: 647-UPW1E221MPD 220uF 25v
    W28-008: C6: 100uF 16v CEA: 647-UPW1E101MED 100uF 25v
    D1: SIB01-005: 512-1N4005
    D2: SIB01-005: 512-1N4005
    D3: SIB01-005: 512-1N4005
    D4 SIB01-005: 512-1N4005
    D5 SIB01-005: 512-1N4005
    D6 SIB01-005: 512-1N4005
    D7 SIB01-005: 512-1N4005
    VR1: 100 ohm single turn: 652-3386F-1-101LF 100 ohm single turn
    Power Supply Board (W16-035)
    W16-035: C2: 1000uF 10v CEA: 647-UPW1E102MHD 1000uF 25v
    W16-035: C3: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
    W16-035: C4: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
    W16-035: C5: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
    W16-035: C6: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
    W16-035: C7: 220uF 35v CEA: 647-UPW1H221MPD 220uF 50v
    D1: SR3AM-8: 512-1N5404
    D2: SR3AM-8: 512-1N5404
    D3: SR3AM-8: 512-1N5404
    D4: SR3AM-8: 512-1N5404
    D5: FR2-02: 512-1N5404
    D7: WZ-130: 512-1N5243B
    Filter caps (need measurements of the main filter caps to determine replacements):
    C33: 4700uF 50V
    C34: 4700uF 50V
    C35: 4700uF 50V
    C36: 4700uF 50V
    C37: 1000uF 63V
    C42: 47uF 50V CEA: 647-UPW1J470MPD 47uF 63v
    BOM List:
    667-ECQ-V1H105JL3 | 2
    647-UKL1H2R2MDDANA | 2
    647-UPW1H4R7MDD | 4
    647-UPW1V100MDD | 8
    647-UPW1J101MPD | 6
    647-UPW1H101MPD | 1
    647-UPW1E101MED | 1
    647-UPW1C330MDD | 2
    667-ECQ-V1H104JL3 | 2
    647-UPW1H221MPD | 2
    647-UPW1E221MPD | 5
    647-UPW1H010MDD | 2
    647-UPW1A220MDD | 2
    647-UPW1J470MPD | 1
    647-UPW1E102MHD | 1
    652-3296Y-1-502LF | 2
    652-3386F-1-202LF | 2
    652-3386F-1-101LF | 1
    512-1N5243B | 3
    512-1N4005 | 7
    512-1N4148 | 1
    512-1N5404 | 5
    Still need to get the filter caps, I also skipped over some of the diodes as well since the datasheets for them are impossible to find.
  6. markthefixer
    21,181
    Bensenville,Illinois
    please write down the datasheet numbers you could not find, and I will look into it as well.
    some of those old units used germanium diodes :yikes:
    I got a bunch of them a while back, just in case!
  7. larryderouin
    22,227
    Glen Burnie Md.
    Mark: Diodes in POST 1 that are in BOLD are the one's I had trouble or not sure on. The one know germanium is on the protection board(W28-008) in position D8 & D9
    D8 VB11-A
    (I found this on the net @ datasheet archives ......spec:Mitsubishi GE-ST 10ma, Uf=0.16V(1mA))
    D9....Same as D8
    NTE lists their replacement as a NTE177. But knowing how much everyone "loves" NTE and how generic their tolerances can be, I left it off.
    And then the 1s1850 @ D6 in the Power supply (w16-035)
    Larry
  8. larryderouin
    22,227
    Glen Burnie Md.
    Matt: The caps I listed for the Power supply should work as a starting point. The can's are clamped & I plan on stuffing my uncles, when I get it here (eventually from Montana). I normally use UVz if i can't get UPW's in the size and with the higher temp rating work well if inside a can.
    Larry
  9. markthefixer
    21,181
    d6 is a dual diode, nothing special, a pair of 512-1n4004's will do.
    d5 the same, 52-1n4004
    protection unit vb11-a : leave them be...
  10. larryderouin
    22,227
    Glen Burnie Md.
    Marks recommendations added to list.
    FINAL LIST! OK TO USE!!!!
    D5: FR2-02: 512-1N4004
    D6:1s1850: 1n4004 (x2) (original is dual diode cathode to center)
    D7: WZ-130: 512-1N5243B[/b]
    D8: Germanium diode leave it be. No readily available replacement.
    D9: Germanium diode, leave it be. No readily available replacement.
    C33: 4700uF 50V
    C34: 4700uF 50V
    C35: 4700uF 50V
    C36: 4700uF 50V
    C37: 1000uF 63V
    BOM List:
    647-UPW1H4R7MDD | 4
    647-UPW1V100MDD | 8
    647-UPW1J101MPD | 6
    647-UPW1H101MPD | 1
    647-UPW1E101MED | 1
    647-UPW1C330MDD | 2
    647-UPW1H221MPD | 2
    647-UPW1E221MPD | 5
    647-UPW1H010MDD | 2
    647-UPW1A220MDD | 2
    647-UPW1J470MPD | 1
    647-UPW1E102MHD | 1
    512-1N5243B | 3
    512-1N4005 | 7
    512-1N4148 | 1
    512-1N5404 | 4
    512-1n4004 | 3
    ..............................end of list........................................................
    Thank you Mark.
    MattSD: I made the changes proposed by MTF. Added 1s1850 (1n4004 x2) changed D5 to
    1n4004. I've used 1n400X in place of FR2-02s in TEAC and FISHER Gear with no problems. BOM Changes made (Subtracted 1-1n5404, added 3 1n4004)
    Larry
    CONSOLIDATED FULL PARTS LISTS HERE:http://www.audiokarma.org/forums/showthread.php?t=549424
    Transistors list only HERE; http://www.audiokarma.org/forums/showthread.php?t=546251
  11. The Fuxtor
    The Fuxtor AK Subscriber Subscriber
    2,979
    Calgary, Alberta
    Bump and a big thanks to everyone who put this very good list together!! Got another back in the saddle! They do sound very good,!! :beerchug:
    dbxdx5 likes this.
  12. The Fuxtor
    2,979
    Calgary, Alberta
    Bumping this once again....
    As I bring this unit out for a rotation, I have noticed that the unit doesn't really sound up to snuff?? After my refurb I never really used it very much but I recently found a matching tx-600 tuner and set them up. Maybe this unit has more of a bloated tone? It sure seems as if it's quite underpowered almost?? Easily distorts with little added bass and less overall clear at higher volumes?
    Operates normal, no oscillation but perhaps the outputs are not ideal??
    I found it sounded pretty much the same with a separate presmp as well ...
    Edit: I just realized that the only thing I never changed were the main power supply filter caps.... Maybe they should be swapped? Sound like a likely culprit??
